Help with HP 830 G5 bios
  • hardware1
    replied
    Re: Help with HP 830 G5 bios
    Originally posted by 11profit
    Thank you
    You're Welcome.
  • Murtaza527
    replied
    Hp elitebook 830 g5
    HI FRIENDS
    PLS ANYONE CAN HELP ME TO REPAIR THIS DUMP
    PROBLEM IS UPDATE NOT SUCCESSFULLY N AUTO OFF
    THANKS IN ADVANCED :rejoice
    HP 830-G5 6050A2030901-MB-A01 (A1)
  • 11profit
    replied
    Use this file with your 32MB Chip and the file which I attached in Post #81 to with your 16MB Chip.
    Thank you
  • lapfix
    replied
    Re: Hp elitebook 830-g5
    Originally posted by Murtaza527
    Hi friends
    pls help me to repair this dump
    problem update not complete n auto restart
    hp 830-g5 6050a2930901-mb-a01 (a1)
    Upload your original bios file
  • Murtaza527
    replied
    Hp elitebook 830 g5
    Hi friends
  • hardware1
    replied
    Im sorry, now its must be good I send two in RAR, because i dont know if first is read okey.
  • 11profit
    replied
    I meant your Main BIOS Chip, not your Main BIOS Menu!
    You already uploaded the EC Chip.
  • hardware1
    replied
    Here we go
  • 11profit
    replied
    Here we go
  • hardware1
    replied
    Thanks ^^ I have question what i can do when HP EndPoint Security Controller Problem pop out? Settings in BIOS dont work.
    If you encounter that Error, just Upload the Main Chip also and we will try to help you.
  • 11profit
    replied
  • hardware1
    replied
    Hello i have problem with my BIOS, can someone unlock that?
    I will be very grateful ^^.
    Here's your Unlocked BIOS, try it.
  • 11profit
    replied
  • mehdiab17
    replied
    thankyu my freind the bios is unlocked
  • hardware1
    replied
    Originally posted by mehdiab17
    hello please i want to unlocked this bios hp 830 g5
    i tried rcunlcker but the bios locked
    Here are your Unlocked Files, program the both chips together.
    In the first boot go to bios menu and disable security options (Default).
  • mehdiab17
    replied
  • bbanana
    replied
    Originally posted by abgsm
    Thanks Bro but still same probleme
    Please any other solution
    hope this file is ok
  • abgsm
    replied
    Originally posted by hoaca388
    HP EliteBook 830 G5 Base Model Notebook PC
  • hoaca388
    replied
    hi to all
    sorry file not uploaded
    Hp elitebook 830 g5
    with originale dump no power can any one help
    file in attached
  • abgsm
    replied
    hi to all
    Hp elitebook 830 g5
    file in attached
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • grimacelord
    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
    by grimacelord
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once...
    05-07-2024, 08:06 AM
  • DynaxSC
    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
    by DynaxSC
    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
    11-06-2022, 05:22 PM
  • vinaypundith
    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
    by vinaypundith
    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
    So, I'm looking for a BIOS dump for this machine - a 16MB one....
    08-03-2024, 12:32 PM
