S5200-802 Toshiba
  • dj_ricoh
    • 2073
    S5200-802 Toshiba
    Hey guys.
    Do I need to reflash to reset the bios or there is a general password that let's me skip it?
    It just hangs there and it doesn't pass.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: S5200-802 Toshiba
    its quite an old model so password is in bios only. Try flashing it first. As you are aware, there may be password reset jumper near ram slot. Look for them as well.
    • dj_ricoh
      • 2073
      I'll open it soon and disconnect the bios battery and see if it works.
      The bios got a strange shape and I don't think my ezp2010 knows how to flash it.
      I hope for the best
        • 20933
        Can you post a photo of the ram slot area and bios,and post bios part number .
        • dj_ricoh
          • 2073
          I swear I don't know what chip is the bios.
          Lol
          • dj_ricoh
            • 2073
            I left the laptop without bios battery for one hour and still nothing.
            Tough tomorrow I'll investigate the pad and that small display.
            There are 3 pcb there. Maybe one is with that bios secure.
            Nevertheless this laptop has some high end build. Seriously.
            Over one hour disassembly .
            Thermal pasts still good after so many year. I mean still liquid if didn't became rock.
            • dj_ricoh
              • 2073
              Can someone move this topic to repair because it needs a full diagnosis
                • 20933
                Did you find the bios chip, i couldn`t see anything on the board
                • dj_ricoh
                  • 2073
                  me either.
                  can't see anything.
                  i took everything out.
                  ill check the bios battery because i had a few old ones that when the bios battery went flat it ask for a password. maybe maybe
                    • 20933
                    Found some more info. The satellite 5200 doesn`t have a paralell port so you can`t remove the pass with a loop back adapter, you need an adapter card and cable.Good luck finding one though.
                    https://www.hobbielektronika.hu/foru....php?id=122509
                    Satellite 5xxx require Printer PC Card (P000293630) and PC Card Cable (P000293640)
                    The user manual says the password is a maximum of 10 characters long,with no special characters.Try a few passwords you might be lucky: TOSHIBA, 5200 ,123456 ,5200802
                    • dj_ricoh
                      • 2073
                      I will.
                      Thank you. This is good info and it's a stepping stone for the future.
                      • dj_ricoh
                        • 2073
                        Any parallel pcmcia card will do?
                          • 20933
                          I don`t know,the pinout for the P000293630 Printer PC Card might be proprietary.Flashing the bios might still be an option if you can find it,it should be 512kb . I`ve extracted the bios update,its 320kb it would need merging with a hex editor.The password could be stored on a different IC .
                            • 20933
                            Card and dongle.
                            https://www.ebay.co.uk/itm/DB25-Prin...r/121531875140
                            http://www.whatsmypass.com/toshiba-laptop-bios-recovery
                            • dj_ricoh
                              • 2073
                              Wow. That's good.
                              U left the board out and I'll take some lens and check every if.
                              I order the pcmcia card. I'll check at work to see if I can get an old cable if not I'll buy one.
                              Ty.
                              • dj_ricoh
                                • 2073
                                Alright. Done the connector and still the same.
                                Moving on to identifying the bios chip?
                                Does it store on the HDD?
                                Should I get a HDD adapter?
                                  • 20933
                                  Do you still get the password = without the hard drive attatched.The dongle might be working ,have you tried entering a new password.The bios chip might be hidden under the white plastic, or metal shields,and could even be part of the lcd pcb , it could be 16 pins, or even a PLCC32 soldered or socketed.
                                  • dj_ricoh
                                    • 2073
                                    I've tested without the pad. nothing. i cant enter bios cant do nothing.100% password protected.
                                      • 20933
                                      Check the TSOP and other IC circled.
                                      • dj_ricoh
                                        • 2073
                                        that one? m50fw040n1
                                        plus when i took the board out the palm rest bent back and fell off and took the power button connector :<
                                        I`ll fix that but the password its harder
                                        • jakobdylan
                                          Toshiba P855 30M BIOS RESET
                                          by jakobdylan
                                          hello please could help me to reset the bios of my toshiba satellite p855-30m
                                          pspkbe-o4x00ktt
                                          serial number 9c017716k
                                          i9c017716ksspkb04x00kitb
                                          04-24-2025, 11:42 AM
                                        • YG007
                                          Asus BIOS How To Reset To Default Settings?
                                          by YG007
                                          Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                                          I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                                          06-05-2023, 08:22 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • llek100
                                          HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
                                          by llek100
                                          Hello, sorry for the long post, I just wanted to include any details that might help.
                                          A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
                                          I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
                                          So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
                                          First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically...
                                          09-18-2024, 09:15 AM
                                        • buduliz
                                          Toshiba Satellite L50-B-1R1 BIOS password reset
                                          by buduliz
                                          Hi there!
                                          As mentioned in title, need a way to remove BIOS password.
                                          MB model DAOBLIMB6FO REV:F
                                          Found G1, G2 and G3 on MB, does shorting method works on this? If so which of those have to be shorted?
                                          Big thanks in advance.
                                          04-18-2025, 04:57 AM
