Dell 15-3576
 Re: Dell 15-3576
 Read the rules before posting:
 Do NOT hijack threads.
 Become a Badcaps supporter
 Thanks to all supporters.
 ----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
 This worked for me.
 Thank you.............Comment
 Hello
 Can someone fix this bios for Dell 15 3576 vegas/turis MLK KBL-R 17841-1
 SERVICE TAGIS/N): JPODDT2
 Laptop work with black screenAttached FilesComment
 hi try new biosAttached FilesComment
 Attached FilesThank you very much, the bios works correctly with Dell Inspiron 3576 MB. Vegas Turis MLK KBL-R 17841-1.
 ME 11.8.55.3510Comment
 THANKS WORKED!!!
			by RofixHi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by JmineHello guys,
 I've got this motherboard with me that turns on when the charger is connected(without pressing the power button), the fan is fully spinning and it doesn't display anything. there is led flashing 3 amber 5 white. voltage readings are also weird, sorry I couldn't find the schematics for the board.
 Voltages are as follows,
 @ PL5301: 1.015V
 @ PL4401: NO voltage
 @ PL4501: 5.100V
 @ PL4502: 3.408V
 @ PL5101 near RTC: NO voltage
 @ PL5001, PL4801 PL4802, PL4701: NO Voltages
 Looking forward for your guidance...
			Dell Inspiron 3462 Turis APL 16823-1 Boardview...-
							Channel: Schematics and Boardviews
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
							Channel: BIOS Requests ONLY!
- Loading...
