ASUS FX504GM bios dump needed!
  • bergusz
    • Sep 2014
    • 19
    • Hungary
    Hi everyone!
    I'm in trouble, I need an ASUS ROG FX504GM dump bios (16Mb)
    Motherboard is DABKLIMBAB0 Rev.B
    I was not able to cut it from factory bios ...
    • 20888
    Re: ASUS FX504 bios dump needed!
    Originally posted by bergusz
    Hi everyone!
    The bios from asus is a bios update,not the full bios.Post your bios backup .
    • bergusz
      • Sep 2014
      • 19
      • Hungary
      Hi!
      Yes, I know, but my original has corrupted/incomplete, because of failed bios update! So I need a complete dump in this case, I think!
      But here it is, if you can use it anyhow:
        • 20888
        Try this bios .There`s no DMI included.
        • bergusz
          • Sep 2014
          • 19
          • Hungary
          You are very kind! Thanx! Will try
          • codigopin
            • Mar 2021
            • 15
            • España
            Hello. I need dabklimbaco rev c bios for repair. I have got corrupt bios but need complete bin. Thanks
            • c.daniel
              • Mar 2017
              • 97
              • Romania
              I report that is working perfect, SMDFlea; thank you very much.
              • HellasTechn1
                • Sep 2015
                • 176
                • Greece
                Re: Asus tuf FX504gm troubleshooting
                the old bios.bin has the contents of the bios when i got if from the repair shop where the laptop turns on keyboard backlight and does nothing more. (just a reminder, the original symptom when i took it there was that when pressing the power key the power led would blink once and then stay off. The charging light would work normally).
                the FX504GM.301.bin i downloaded from somewhere and came with an EC.bin that i can not program into the SIO chip since i dont have a suitable programmer and gives me almost the same results (the laptop turns on keyboard backlight and does nothing more) but the charge light does not come on when i connect the power adapter with the battery connected.
                the FX504GM ME_CLEAN is the clean bios and again it gives me the same results
                but the charging light works normally (lits red) when i connect the power adapter with the battery connected.
                P.S.
                Please note that my xeltek 6100n programmer reads my bios chip as (GD25B128C). It does not have the GD25B127DSIG in it's device list.
                • HellasTechn1
                  • Sep 2015
                  • 176
                  • Greece
                  Re: ASUS FX504GM bios dump needed!
                  Are theede bin files suitable for my laptop ? Please any advice highly appreciated since i payed 450 euro for this used laptop (as is) and it only worked 1 day
                  I do suspect problem with the SIO chip. at the workshop where i took it they told me that the chipset is bad and they couldnt do anything about it. discussion here : https://www.badcaps.net/forum/showthread.php?t=110769
                  Thank you all !!!
                    • 20888
                    Thank you all !!!
                    Post the laptop serial number
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      Here's your New BIOS, try it and give me the results.
                      Serial Number: J9NRCX04A990401.
                      all donations are welcome,
                      • HellasTechn1
                        • Sep 2015
                        • 176
                        • Greece
                        Yes that is the serial number all right : J9NRCX04A990401.
                        I am going to try this bios on monday and let you know. Many thanks !!!
                        • HellasTechn1
                          • Sep 2015
                          • 176
                          • Greece
                          I had the chance to remove the bios from the machine, erase it, program it with the above .bin file and re solder it on the machine.
                          The laptop now looks completely dead. No action when i press the power button, no lights turn on and the charging light does not turn on when i connect the charger. I do have 3.3 volts on the bios chip though (pin 4 gnd, pin 8 vcc).
                          unfortunately i do not know where to look for other voltages...
                          P.S. Since i dont want to mess up your forum, should i keep writing here or take it back to the other thread? thanks.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            No. If you want further help beyond a bios request - at the other thread only.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • HellasTechn1
                              • Sep 2015
                              • 176
                              • Greece
                              Hello. i have one last question about my bios.
                              Does it have kbc bios inside it ?
                              Thank you !
                              • HellasTechn1
                                • Sep 2015
                                • 176
                                • Greece
                                Is this a clean me bios ? I am asking because i need it to be clean me.
                                I have replaced the kbc (sio chip) with a new blank one and i want to flash the bios with a clean me one so that at first power up the kbc will be self programed and hopefully my machine will work.
                                Thank you.
                                • HellasTechn1
                                  • Sep 2015
                                  • 176
                                  • Greece
                                  Please, it is very important that i flash the correct bios firmware with clean me since i only have one shot for correct programming of the SIO chip.
                                  • hardware1
                                    • Sep 2021
                                    • 2930
                                    • N/A
                                    Thank you.
                                    Yes, the ME Region is clean and the BIOS has EC firmware inside it.
                                    Remember to do verification after flashing the BIOS.
                                    • HellasTechn1
                                      • Sep 2015
                                      • 176
                                      • Greece
                                      Thanks !
                                      By the way , which program do you use to read the.bin file ?
                                      • hardware1
                                        • Sep 2021
                                        • 2930
                                        • N/A
                                        Thanks !
                                        If you asking for which Hex Editor I use to open the bin files, I use HxD.
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
