ASUS FX504GM bios dump needed!
  • bergusz
    • Sep 2014
    • 19
    • Hungary
    Hi everyone!
    I'm in trouble, I need an ASUS ROG FX504GM dump bios (16Mb)
    Motherboard is DABKLIMBAB0 Rev.B
    I was not able to cut it from factory bios ...
    • 21907
    Re: ASUS FX504 bios dump needed!
    Originally posted by bergusz
    Hi everyone!
    The bios from asus is a bios update,not the full bios.Post your bios backup .
    • bergusz
      • Sep 2014
      • 19
      • Hungary
      Hi!
      Yes, I know, but my original has corrupted/incomplete, because of failed bios update! So I need a complete dump in this case, I think!
      But here it is, if you can use it anyhow:
        • 21907
        Try this bios .There`s no DMI included.
        • bergusz
          • Sep 2014
          • 19
          • Hungary
          You are very kind! Thanx! Will try
          • codigopin
            • Mar 2021
            • 15
            • España
            Hello. I need dabklimbaco rev c bios for repair. I have got corrupt bios but need complete bin. Thanks
            • c.daniel
              • Mar 2017
              • 108
              • Romania
              I report that is working perfect, SMDFlea; thank you very much.
              • HellasTechn1
                • Sep 2015
                • 176
                • Greece
                Re: Asus tuf FX504gm troubleshooting
                the old bios.bin has the contents of the bios when i got if from the repair shop where the laptop turns on keyboard backlight and does nothing more. (just a reminder, the original symptom when i took it there was that when pressing the power key the power led would blink once and then stay off. The charging light would work normally).
                the FX504GM.301.bin i downloaded from somewhere and came with an EC.bin that i can not program into the SIO chip since i dont have a suitable programmer and gives me almost the same results (the laptop turns on keyboard backlight and does nothing more) but the charge light does not come on when i connect the power adapter with the battery connected.
                the FX504GM ME_CLEAN is the clean bios and again it gives me the same results
                but the charging light works normally (lits red) when i connect the power adapter with the battery connected.
                P.S.
                Please note that my xeltek 6100n programmer reads my bios chip as (GD25B128C). It does not have the GD25B127DSIG in it's device list.
                • HellasTechn1
                  • Sep 2015
                  • 176
                  • Greece
                  Re: ASUS FX504GM bios dump needed!
                  Are theede bin files suitable for my laptop ? Please any advice highly appreciated since i payed 450 euro for this used laptop (as is) and it only worked 1 day
                  I do suspect problem with the SIO chip. at the workshop where i took it they told me that the chipset is bad and they couldnt do anything about it. discussion here : https://www.badcaps.net/forum/showthread.php?t=110769
                  Thank you all !!!
                    • 21907
                    Thank you all !!!
                    Post the laptop serial number
                    • hardware1
                      • Sep 2021
                      • 2948
                      • N/A
                      Here's your New BIOS, try it and give me the results.
                      Serial Number: J9NRCX04A990401.
                      all donations are welcome,
                      • HellasTechn1
                        • Sep 2015
                        • 176
                        • Greece
                        Yes that is the serial number all right : J9NRCX04A990401.
                        I am going to try this bios on monday and let you know. Many thanks !!!
                        • HellasTechn1
                          • Sep 2015
                          • 176
                          • Greece
                          I had the chance to remove the bios from the machine, erase it, program it with the above .bin file and re solder it on the machine.
                          The laptop now looks completely dead. No action when i press the power button, no lights turn on and the charging light does not turn on when i connect the charger. I do have 3.3 volts on the bios chip though (pin 4 gnd, pin 8 vcc).
                          unfortunately i do not know where to look for other voltages...
                          P.S. Since i dont want to mess up your forum, should i keep writing here or take it back to the other thread? thanks.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            No. If you want further help beyond a bios request - at the other thread only.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • HellasTechn1
                              • Sep 2015
                              • 176
                              • Greece
                              Hello. i have one last question about my bios.
                              Does it have kbc bios inside it ?
                              Thank you !
                              • HellasTechn1
                                • Sep 2015
                                • 176
                                • Greece
                                Is this a clean me bios ? I am asking because i need it to be clean me.
                                I have replaced the kbc (sio chip) with a new blank one and i want to flash the bios with a clean me one so that at first power up the kbc will be self programed and hopefully my machine will work.
                                Thank you.
                                • HellasTechn1
                                  • Sep 2015
                                  • 176
                                  • Greece
                                  Please, it is very important that i flash the correct bios firmware with clean me since i only have one shot for correct programming of the SIO chip.
                                  • hardware1
                                    • Sep 2021
                                    • 2948
                                    • N/A
                                    Thank you.
                                    Yes, the ME Region is clean and the BIOS has EC firmware inside it.
                                    Remember to do verification after flashing the BIOS.
                                    • HellasTechn1
                                      • Sep 2015
                                      • 176
                                      • Greece
                                      Thanks !
                                      By the way , which program do you use to read the.bin file ?
                                      • hardware1
                                        • Sep 2021
                                        • 2948
                                        • N/A
                                        Thanks !
                                        If you asking for which Hex Editor I use to open the bin files, I use HxD.
                                        • ArkzG
                                          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                          by ArkzG
                                          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                          What I currently have available:
                                          - Model: FA506NF (2021)
                                          - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                          - Tools: CH341A programmer ready to use
                                          Does anyone have either a clean 2MB .bin dump of this model,...
                                          09-26-2025, 09:34 PM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          08-16-2025, 12:20 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
