Alienware M14x R2 bios password
  • chipside
    • Dec 2022
    • 3
    • Philippines
    Help on Removing Password on Dell Alienware
    I Have a Dell alienware M14x r2
    I have followed instructions in this forum and already have Password from the dell generator.
    Just want to ask how to use these??? Or where to put it to remove setup password on my laptop? Thanks for any help.
    • AAAC
      • Jan 2020
      • 458
      • Mexico
      Re: Help on Removing Password on Dell Alienware
      The problem with Dell models using 16-hex System Disabled algorithm is if you don't do it right it won't clear the password, upon reboot it will ask for the password again. Some models require you to type the password followed by (CTRL-ENTER) twice instead of just ENTER, if this does not work, then just type the password + ENTER.
      So just type the password every time you are asked for a BIOS or SYSTEM password, prevent from getting "incorrect password" more than 2 times, otherwise the System Disabled 16-hex code will change on the third incorrect password and you will need to generate another password for the new code again.
      Alienware M14x R2
      • suff0beast
        • Aug 2024
        • 3
        Is this still a thing?
        If so, I pulled my Alienware M14x from the closet and trying to set it up for some general randomness
        I get the following code on my system when attempting to unlock setup in BIOS:
        System Disable:
        598CE4F9269E47CD
        Service Tag:
        3MBYLX1
        If anyone is still able to generate an override password that would be great!
        Rick
        • volinakis
          • Jan 2021
          • 2728
          • N/A
          System Disable:
          598CE4F9269E47CD
          Service Tag:
          3MBYLX1
          Rick
          try: 59445771
          • suff0beast
            • Aug 2024
            • 3
            Originally posted by volinakis
            try: 59445771
            That worked! Thank you so much
            Rick
            • Matt Kelly
              • Oct 2024
              • 3
              • usa
              #26
              looks like you guys are having good luck could somebody help me alienware 14 E5D397A3C40BA871 SERVICE TAG BB4TVZ1
              • volinakis
                • Jan 2021
                • 2728
                • N/A
                #27
                64363414
                • Matt Kelly
                  • Oct 2024
                  • 3
                  • usa
                  #28
                  W😁w worked like a charm!! Thanks bro your a genius!!!!
                  • Almorrison
                    • Jan 2025
                    • México
                    #29
                    Please, somebody could help me with my alienware M14X R2? the System Disable is 12B3C17EEA6D34D7 and the Service Tag is 8K6QHV1. Thanks.​
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      #30
                      Try this Password:
                      70910469
                      You have to press CTRL+ENTER+ENTER after typing the password instead of ENTER.
                      all donations are welcome,
                      • Almorrison
                        • Jan 2025
                        • México
                        #31
                        Try this Password:
                        70910469
                        OMG! That works, thank you so much, you are the best.
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          #32
                          You're welcome.
                          • Rja328
                            • Jan 2025
                            • 4
                            Hello everybody,
                            I hope somebody can still help me with my problem, I have acquired an old Alienware m14x R2 that has an Admin password on the bios which I cant access the bios settings because its disabled by the old owner. Please help me if somebody can give me the password
                            Service tag : 4WPGDS1
                            Thank you in advanced 😃
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              #34
                              Originally posted by Rja328
                              Hello everybody,
                              Try to type wrong password 3 times and post your service tag with the system disable as post #29
                              • Rja328
                                • Jan 2025
                                • 4
                                Thank you for the reply, I tried more than three times but it didn’t show any system disabled code.
                                when I go to Security tab - Locked setup - it says “Unlock Setup? I tried a lot of wrong password and it shows Unlock Setup fail [ Press any key ]
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  #36
                                  Type 3 wrong password in "Unlock Setup".
                                  • Rja328
                                    • Jan 2025
                                    • 4
                                    I tried more than 3 wrong passwords, and it still goes back to unlock set up fail as shown in the pics which is weird
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11682
                                      #38
                                      Post origin bios file.
                                      • Rja328
                                        • Jan 2025
                                        • 4
                                        Thanks for the response. I dont know where to look for the origin bios file but i have attached the main tab if it helps.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11682
                                          #40
                                          https://www.badcaps.net/forum/troubl...rces-and-tools
                                          https://www.youtube.com/results?sear...+to+use+ch341a
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • GIGA10
                                            Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
                                            by GIGA10
                                            Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
                                            I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
                                            12-23-2022, 03:31 AM
                                          • drux
                                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                            by drux
                                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                            These models have AMI/Aptio BIOS.
                                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                            11-03-2024, 01:18 AM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
