need acer f5-573g bios dump.
Da0zaamb8d0 rev:d bİos dump
Re: Da0zaamb8d0 rev
bİos dump
Use the SEARCH !Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
post it here please not on dosya.Comment
Re: Da0zaamb8d0 rev
bİos dump
This FİLE İS BrokenAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
Try this one, the file posted in the other thread says its clean,but it isn`t. This bios doesn`t have any DMI info, if you need to enter it search the forum for the acer DMI tool .Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
The ME is clean,if it still has a late image after a reboot you can force the PCH to reset and accept the new ME changes using FPT Flash Programming Tool. Run the command:
fpt -gresetAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
hi
i uploaded the original file, can you fix it?
I have tried the bios file installed here, but can you edit my own bios file to start different keys on the keyboard?Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
https://www.badcaps.net/donateComment
Re: Da0zaamb8d0 rev
bİos dump
try this oneAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Da0zaamb8d0 rev
bİos dump
Hello Sir
Pls help to repair my bios
i used file from #10 and it's working perfecto
thank in advacedAttached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
