Alienware 18 Bios extraction help
  • Safio
    • Jun 2017
    • 46
    hello,
    please i want to extract an Alienware 18 bios (need it for bios recovery,blind flash) any help will be very appreciated
    thank you
  • drux
    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
    by drux
    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
    These models have AMI/Aptio BIOS.
    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
    11-03-2024, 01:18 AM
  • Svyatpro
    Alienware X17 R2 (LA-L613P) need BIOS dump or BIOS extract
    by Svyatpro
    Hello folks.
    I have Alienware X17 R2 (LA-L613P) with broken BIOS after unsuccessful BIOS update.
    Dell_PFS_Extract cannot extract BIOS from bios update.
    Here is my dump....
    03-17-2024, 12:41 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • SCREAM76
    Alienware m18 R2 Bios pls
    by SCREAM76
    Alienware m18 R2 i9 cpu no screen 5 blue 3 red blink
    I added the original bios. I need a clean me or a new working bios.
    Alienware m18 R2
    Servis tag: 4SWZH54
    Serial: 10455585160​...
    11-01-2025, 08:32 AM
  • survivalbloke
    Unable to extract bios file from Lenovo bios exectuable
    by survivalbloke
    I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
    Code:
    "innoextract 7wcn38ww.exe"
    it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
    The trouble I'm having is that I'm not getting the newly...
    06-12-2024, 07:55 AM
