Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Hello, I need bios & ec , board BDL50 LA-D704P REV:4.0, HP laptops.
    I replace kbc KB9022Q D, kbc short circuit line 3,3V.
    Regards.
    • 22119
    Re: Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
    Post your bios backup, and give laptop model number such as 15-bd003tx.
    • warsztat
      • Feb 2017
      • 190
      • Polska
      I have only board, I will get the data and give it. Thank you.
      • ardeyalex
        Banned
        • Feb 2014
        • 36
        • Romania
        https://*******************/product/hp-15-bd-la-d704p/
          • 22119
          Ok .The bios update has 5 different bios versions,so your bios backup is needed to check which one is the right one.
          • warsztat
            • Feb 2017
            • 190
            • Polska
            bios for HP 250 G5 / Product: Z3A54ES#AKD
            I will try it in a few hours, now other works.
            • warsztat
              • Feb 2017
              • 190
              • Polska
              my bios :
              https://www.badcaps.net/forum/attach...1&d=1555339208
              bios from ardeyalex not work, after push power button current power ~10-20mA, i not sure is board ok, i had to replace KB9022Q
                • 22119
                Here`s your bios,its a full bios extracted from the hp update with your win key added.
                • warsztat
                  • Feb 2017
                  • 190
                  • Polska
                  Still wrong, I think so problem hardware. After push power buton UC1 not read UC2 (25B64), 3,3V ok, no clk pin7, oscillations YC2 UC1 ok. Or wrong EC 128kb in KB9022 inside memory, is possible ?
                  I hope that I will be understood.
                    • 22119
                    It could be the KB9022.Most of the ITE,Nuvoton,ENE chips for sale are used .
                      • 22119
                      Here is the EC , its cut from the bios i posted .bios id BID081EC .
                      The other bios id`s are on another post for anyone else looking,there are 5 different bios id`s for the LA-D703P and LA-D704P
                      https://www.badcaps.net/forum/showthread.php?p=739852 Post #9
                      • bineesh.avb
                        • Jun 2016
                        • india
                        hi bros......any one has la-d704 io programming connection points details
                        • piszpunta
                          • Jan 2019
                          • 260
                          • poland
                          HP 15-be012tu bdl50 la-d704p rev 4.0
                          Need Bios dump AND KBC HP 15-be012tu
                          MOTHERBOARD : bdl50 la-d704p rev 4.0
                          CPU : SR2UW Intel i3-6006U
                          GPU NONE ONLY INTEL
                          KBC : ENE KB9022Q D
                          MY ORYGINAL BIOS DUMP HERE
                          • peste
                            • Dec 2016
                            • 13759
                            • ROMANIA
                            Re: HP 15-be012tu bdl50 la-d704p rev 4.0
                            try post#14
                            https://www.badcaps.net/forum/showthread.php?t=57159
                            • piszpunta
                              • Jan 2019
                              • 260
                              • poland
                              Originally posted by peste
                              no change. black screen
                              • peste
                                • Dec 2016
                                • 13759
                                • ROMANIA
                                try
                                • peste
                                  • Dec 2016
                                  • 13759
                                  • ROMANIA
                                  try...
                                  • piszpunta
                                    • Jan 2019
                                    • 260
                                    • poland
                                    I'll check tommorow
                                    • peste
                                      • Dec 2016
                                      • 13759
                                      • ROMANIA
                                      Originally posted by piszpunta
                                      I'll check tommorow
                                      try..
                                      • piszpunta
                                        • Jan 2019
                                        • 260
                                        • poland
                                        try..
                                        No change
                                        maybe this is KBC??
                                        my oryginal KBC dump here:
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
