hi there , have this laptop for ages as it has a bios password , tried to find a dump file for it but no luck , DAX93AMB6G0 REV G , MODEL X93A ,TPT MV-0 20 E88441 94V-0 , anyone has this dump file?
hp probook 455 g4 dump file
Re: hp probook 455 g4 dump file
Post your bios backup. -
here you goAttached Filesif you find these attachements useful please consider making a small donation to the site
Try this .Attached Filesif you find these attachements useful please consider making a small donation to the site
ok , flash this one, its the full bios straight from hp.Attached Filesif you find these attachements useful please consider making a small donation to the site
@smdflea has very good experience in fixing bios and hp virgin bios should work. You said the laptop lying for long time. You got display before flashing bios??Comment
yes , it works fine , the chip model is 25B128CSIG, when i use "detect" on ch431a programmer shows memory type :GD25Q128 , using this config i could read the chip , erase , and write, but i get verifying problem "chip main memory with the contents are in disagreement" , now it gives the same led flashing after restoring the original dump file which i backed up, anyway to fix that?Comment
Hi, i have same password issue and i've flashed using all dumps above but not working for me. pls can anyone help remove password?Comment
Hello guys, I need help to get a new bios for my hp probook 455 G4
The marking of the motherboard is DAX93AMB6G0 REV :G
SN 5CD74597B4Attached Filesif you find these attachements useful please consider making a small donation to the site
Read the rules before posting:
Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Oh, I'm sorry.. the problem is that when it turns on, the screen remains black, and the fan from the processor starts to whine more and more.Read the rules before posting:
.Comment
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with make, model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
dax93amb6g0 rev g bios
this one tested working 100% without any passwordAttached Filesif you find these attachements useful please consider making a small donation to the site
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
- Loading...
