hp probook 455 g4 dump file
  • layad
    • Nov 2011
    • 244
    hi there , have this laptop for ages as it has a bios password , tried to find a dump file for it but no luck , DAX93AMB6G0 REV G , MODEL X93A ,TPT MV-0 20 E88441 94V-0 , anyone has this dump file?
    • 22077
    Re: hp probook 455 g4 dump file
    Post your bios backup.
    • layad
      • Nov 2011
      • 244
      here you go
        • 22077
        Try this .
        • layad
          • Nov 2011
          • 244
          after flashing the dump , laptop led (charger indicator) blinking all the time and the laptop is no turning on!!!!
            • 22077
            ok , flash this one, its the full bios straight from hp.
            • layad
              • Nov 2011
              • 244
              still the same , flashing led
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                @smdflea has very good experience in fixing bios and hp virgin bios should work. You said the laptop lying for long time. You got display before flashing bios??
                • layad
                  • Nov 2011
                  • 244
                  yes , it works fine , the chip model is 25B128CSIG, when i use "detect" on ch431a programmer shows memory type :GD25Q128 , using this config i could read the chip , erase , and write, but i get verifying problem "chip main memory with the contents are in disagreement" , now it gives the same led flashing after restoring the original dump file which i backed up, anyway to fix that?
                  • layad
                    • Nov 2011
                    • 244
                    sorted , thank you, it was my mistake , i used now flashrom instead of the normal ch341a app
                    • gearsofwarrock
                      • Jan 2020
                      • mexico
                      i need these program, i have problems with the 25b128csig and the ch341a pro, can you help me?
                      • yungprof4u
                        • Aug 2020
                        • 5
                        • Nigeria
                        Hi, i have same password issue and i've flashed using all dumps above but not working for me. pls can anyone help remove password?
                        • yungprof4u
                          • Aug 2020
                          • 5
                          • Nigeria
                          Both dumps contain password, can anyone help remove?
                          • ribar96
                            • Apr 2023
                            • 36
                            • Bosna and Herzegovina
                            Hello guys, I need help to get a new bios for my hp probook 455 G4
                            The marking of the motherboard is DAX93AMB6G0 REV :G
                            SN 5CD74597B4
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              SN 5CD74597B4
                              Read the rules before posting:
                              Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                              • ribar96
                                • Apr 2023
                                • 36
                                Oh, I'm sorry.. the problem is that when it turns on, the screen remains black, and the fan from the processor starts to whine more and more.
                                • alexplamkop
                                  • Feb 2023
                                  • 10
                                  • thai
                                  thank a lot
                                  • ameerrrr
                                    • Aug 2015
                                    • 42
                                    • syria
                                    bios hp 455 g4 with DMI
                                    DAX93AMB6G0 REV G
                                  • bel77
                                    • May 2013
                                    • 34
                                    • jordan
                                    dax93amb6g0 rev g bios
                                    this one tested working 100% without any password
                                    • Gado229
                                      • Aug 2023
                                      • 22
                                      • Benin
                                      Hello everyone, I have programmed the bios of a hp 455 g4 but I forgot to copy the old file, can you help me to find a good file
