looking for a working bios file motherboard code is ms-16gd1 ver:1.1
Msi ms-16gd
Re: Msi ms-16gd
The full bios is available at MSI support, download the correct bios for your model,extract the zip file. https://www.msi.com/Laptop/support/cx61#down-biosComment
Re: Msi ms-16gd
try this
and replyAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Msi ms-16gd
thanks everybody for responce............finally i done it here the fileAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Msi ms-16gd
Great. Always check on MSI ,the full bios is usually there if you check with the full laptop model number.Comment
this is GOOD dump for MSI CX61-2PC--MS16GD tested
Hello, I have an MSI device and I can't remove the BIOS password. I'm sharing the original BIOS and its information with you. Can you remove the BIOS password? 😊
Model: MSI MS-16GD
MB INFO
E89382 MV-4
94V-0
MS-16GD1 VER: 1.1Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
Hello again,
I need bios password reset. Thank you so much!
Model: MSI MS-16GD
MB INFO
E89382 MV-4
94V-0
TRYAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
