Asus x55a bios to be fix
  • Usedcom
    Usedcom
    • Dec 2015
    • 24
    • Polska
    Re: Asus x55a bios to be fix
    Originally posted by SMDFlea
    Here you go .
    ok thanks
    • kukuxumusu
      El Flaco
      • Aug 2024
      Hi guys,
      How did you actually flash your BIOS on ASUS X55A using that modified .bin file?
      I tried flashing using AFU on Windows but I get an error that no driver was found.
      I tried flashing via EFI in BIOS but I could not get the EFI boot option running.
      Please help me.
      Which method works and which steps do I have to accomplish?
      • hoaca388
        Badcaps
        • Jan 2022
        • 11732
        Originally posted by kukuxumusu
        Hi guys,
        Please help me.
        Via a programmer.
        • markoclick1993
          • Apr 2020
          • Románia
          Originally posted by qayyum786
          Re: ASUS X55A REV:2.2 bios help
          ENJOY NEW MODDED BIOS WITH CLEAN ME
          Working! Thank you!
          • kukuxumusu
            El Flaco
            • Aug 2024
            Originally posted by markoclick1993
            Working! Thank you!
            So you bought a BIOS programmer, put in the BIOS chip of the X55A, flashed with that bin file and then you put the BIOS chip back in the laptop?
            • peste
              • 12786
              • ROMANIA
              #26
              What's wrong with the laptop? What do you need..???
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • maciek1221
                Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
                by maciek1221
                Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
                Config:
                Model: Asus G512LV-HN235T
                Platforma: G532LWS rev. 1.3
                CPU: intel i7-10870H
                GPU: nVidia Geforce RTX2060/...
                03-07-2024, 07:54 AM
              • Technodoc
                ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                by Technodoc
                Asus laptop G614JZ-N3012W Rog Strix with i7
                Mainboard G634J-PMV-VGT
                6050A3441302-MB-A01
                2023-02-10
                Power button works okay....power light goes on
                Red "bottom" leds go on
                Charging led works
                Fans do not spin, capslock key does nothing, screen stays black
                I would like to program the bios again, to rule out a corrupted bios.
                However I run into a size error
                The bios chip is a Winbond 25R256JVEN
                Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                02-24-2025, 04:46 AM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
