Help bios locked !! Model 6470b
  • dinouz
    • Feb 2019
    • 6
    • france
    Could you help me please.
    I posted a previous post but I did not get a favorable answer.
    My bios is locked, I can not boot to CD or USB, only HARD DISK.
    My model is a 6470B, I'm talking about dump file but I do not know how to get it.
    Do you have a method? Can you help me please .
    I thank you in advance.
  • dinouz
    • Feb 2019
    • 6
    • france
    Re: Help bios locked !! Model 6470b
    Can you answer me ??? Please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      The hp site doesnt have full bios for your model, only update file. Post your backup here so that someone can merge it with hp update.You yourself can do it with UEFI Tool if you know how to do it.
      • dinouz
        • Feb 2019
        • 6
        • france
        I can't boot on usb or CD , only hard disk. I Can't flash my bios because i have a password.
        Can you help me, ? i don't find a procédure
          • 22279
          • hyditech
            • Jun 2012
            • 272
            • nigeria
            GO get a bios programmer
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              enter invalid bios code 3 time, but don't rush, because you will be prompted to choose: system shutdown, or enter unlock code/password.
              After choosing enter unlock code, you will be prompted with a window that has a reset key written. You give me this key, and i generate a user password, so you could enter bios.
              To remove supervisor key, you use generated user password I provided. Because to change supervisor key, you have to enter current password, which is generated password.
                • 22279
                As requested in pm .Try flash programming tool , 32bit .
                • opensourcefan
                  Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS
                  by opensourcefan
                  Hey all, I have a Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS. I would like to unlock it.
                  Currently I have it apart in all its glorious bits looking for the security eeprom that I can't find. Plan was to jump it. Next step I think is to pull the BIOS IC and flash a decryption file to it?? I'm a bit confused on that process.
                  1. Pull the BIOS IC,
                  2. Read and save the original locked file
                  3. Flash the decryption file
                  4. Install and boot up and remove password from BIOS
                  5. Remove BIOS IC again
                  6. Flash Original locked...
                  11-19-2022, 06:18 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • TyMercer
                  Can I flash a working BIOS from one computer to another of the same make, model, etc?
                  by TyMercer
                  Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                  11-13-2025, 09:39 PM
                • Loki_Fido
                  BIOS for Microsoft Surface Laptop 7 - Model 2036
                  by Loki_Fido
                  Hi ya folks,
                  Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
                  As of right now i am unable to confirm whether this BIOS dump works or not.
                  But i will update soon. Hopefully in a day or two.
                  Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
                  Microsoft Surface Laptop 7th edition
                  Model 2036
                  SN 0F3CPFB24153HH
                  Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
                  Both ASProgrammer...
                  09-11-2025, 04:00 AM
                • fulaphex
                  Lenovo Thinkpad X13 Gen 3 AMD locked bios
                  by fulaphex
                  hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                  I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                  07-09-2025, 07:04 PM
