ACER E5-571-30AB LA-B161P BIOS RECOVERY stop
  • xfor62
    • Feb 2019
    • 14
    • France
    i have an acer e5-571 laptop which doesn't work.
    When i power on, blue led is switch on and nothing else.
    So i unassemblied the laptop to remove wifi card, hdd, memory, etc ... but still not start
    So i tried a bios recovery with the next steps :
    * unplug battery, ac power
    * download last bios from acer website (v1.32)
    * burn only bdw.fd file to an bootable usb key, rename the file to Z5WAHx64.fd
    * plug the usb key to the laptop
    * hold FN+ESC keys
    * plug AC power
    * power on
    * let go of FN+ESC key
    fan ran high speed
    USB Key light blinked so i think acer tried to read the fd file
    and few seconds later (maybe 5-6 seconds), the laptop power off and nothing else
    i tried several times, with several usb port but the recovery don't work.
    i tried others bios version, from 1.24 but don't work.
    BIOS before don't have a fd file
    I read a lot of blogs which indicate that acer bios update often break the bios.
    How can i recover the bios program without changing the chip ?
    Can you help me to diagnostic what is the problem ?
    Thks in advance
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3637
    • slovakia
    Re: ACER E5-571-30AB LA-B161P BIOS RECOVERY stop
    no need to change chip, just program it. programmer cost 2euros on aliexpress
    • xfor62
      • Feb 2019
      • 14
      • France
      Hello ktmmotocross
      thanks for your response.
      Do you mean i can reprogramm the bios chip without unsoldering it just with a soic8 clip as ch341A ?
      i'm not afraid to do this but what is the steps to do ?
      Do i need a special software ? shall i use a second laptop to program the chip and what is the file to use to program the chip ?
      I didn't find anything for this on the web
      thks
      • xfor62
        • Feb 2019
        • 14
        • France
        Hi ktmmotocross
        it worked fine with a ch341a programmer.
        i was able to start again the laptop with bios v1.04 found on this forum, reinstall win10, update bios to v1.32 found on acer drivers site and all work fine.
        i've got a new laptop to replace my old asus x71sl.
        thks
        • EbrahimSiami
          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
          by EbrahimSiami
          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
          **What I have tried so far:**
          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
          07-02-2025, 02:31 PM
        • Wg188
          ACER Veriton Z4660G AIO bios help
          by Wg188
          I have an Acer veriton Z4660G all in one pc,
          Model: Z4660G-I5850H1 (VZ4660G_W)
          Need bios dump and schematic would save my life !
          to make a long story short I bought this all in one used
          with a broken lcd, with the objective of making a custom desktop out of it
          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
          06-17-2023, 02:20 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • James194zt
          Acer Nitro 50-640E Corrupted BIOS Dump
          by James194zt
          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
          04-28-2025, 03:29 PM
        • sssssssssssssss
          Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
          by sssssssssssssss
          I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
          Symptoms:
          • Laptop powers on but no display at all (completely black screen)
          • Caps Lock blinks twice with a pause, then repeats continuously
          • F12 LED stays on permanently
          • No POST, no boot sequence, nothing on screen
          Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
          What I've tried:
          • Hardware reset (battery removal, power
          09-04-2025, 06:45 AM
