LEnovo ideapad 110 need to fix bios
  • Romy2018
    • Sep 2018
    • 174
    • japan
    Can someone fix this dump please
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: LEnovo ideapad 110 need to fix bios
    Bios with your DMI + Win Key + EC file .
    - Model - Lenovo ideapad 110-15ACL
    - MTM - 80TJ00LRUS
    - SN - PF0RBXXX
    - SN Board - 112555720XXXX
    - UUID - 861CA0EE-32C2-11E7-8FF554E1AD1XXXXX
    - Mac Addres - 54-E1-AD-19-XX-XX
    - Windows KEY : 2W4RY-RN7T6-BR3J2-J7YDF-XXXXX
    • Romy2018
      • Sep 2018
      • 174
      • japan
      thanks i flashed the bios main its working but after 20minutes it shuts off and orange light blinking
      • Romy2018
        • Sep 2018
        • 174
        • japan
        the battery light is blinking
        • Andrew_R
          Banned
          • Jun 2018
          • 91
          • Poland
          Try flash EC if not help then you have hardware problem .
          • Romy2018
            • Sep 2018
            • 174
            • japan
            thanks for the response that is my problem i dont have ec programmer
            • Romy2018
              • Sep 2018
              • 174
              • japan
              it can turn on display comes but the orange charging light is blinking and after 20mins it goes off
              • mximiliandz
                help bios lenovo ideapad s145-14iil type 81w6
                by mximiliandz
                Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                06-20-2025, 06:50 AM
              • jendkkd jeje
                Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                by jendkkd jeje
                So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                10-11-2024, 03:12 PM
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • hirens
                Lenovo ideapad 3 14IGL05 bios dump needed
                by hirens
                model: 81wh
                sn: pf36ta6h
                board no: nm-c961 gs453/gs553
                hey guys above is my laptop info
                it only blinks the power button kindly help me with a working dump
                old dump attached...
                07-21-2023, 04:48 AM
              • lngcs
                Bios dump need for lenovo ideapad 1 15ALC7
                by lngcs
                Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks...
                09-24-2024, 11:11 PM
