need bios file for cp692725-z3 bios
  • uvaiz
    • Jan 2014
    • 113
    • saudi arabia
    fujitstu lifebook e756 , cp692725-z3 bios
    • 22279
    Re: need bios file for cp692725-z3 bios
    Post your bios backup .
    • uvaiz
      • Jan 2014
      • 113
      • saudi arabia
      my backup ,,no display
        • 22279
        Try this one,your DMI info included.
        EDIT: EC Firmware update,flash from windows http://support.ts.fujitsu.com/IndexD...7-C51D755FDA5A
        • uvaiz
          • Jan 2014
          • 113
          • saudi arabia
          thank you for your support,,,,
          still same problem no display..
            • 22279
            Ok , try this one .
            • uvaiz
              • Jan 2014
              • 113
              • saudi arabia
              working,,,thankss:
                • 22279
                You`re welcome .
                • Rajab Ali
                  • Aug 2023
                  • Pakistan
                  need Bios CP692725-Z4
                  • peste
                    • 13924
                    • ROMANIA
                    post S/N, full name and model, motherboard model, etc.
                    post the contents of the bios chip even if it is corrupted..
                    • babarali
                      • Jun 2023
                      • 19
                      • Pakistan
                      Fujitsu t936 cp694581-z4 bios bin ,,,,,,,,100% ok
                      • m1ch43lzm
                        by m1ch43lzm
                        Hi everyone
                        09-06-2025, 05:47 PM
                      • to5it0
                        by to5it0
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maanee11
                        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                        by maanee11
                        Hello Everyone,
                        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                        In the website, you can only see specs etc.
                        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                        11-08-2025, 04:08 AM
                      • Forest79
                        by Forest79
                        07-23-2023, 07:39 AM
