Lenovo IdeaPad 110 NM-A841 bios needed
  • peste
    • Dec 2016
    • 12775
    • ROMANIA
    Re: Lenovo Ideapad 110-15ACL NM-A841 EC
    Originally posted by teckhing79
    anyone got this EC bios?
    board model : NM-A841
    EC Model IE8586E -FXA
    make a backup copy of the EC bios, and try the EC bios from post # 2.
    • Issiak87
      • Sep 2021
      • 15
      • Bénin
      Re: bios lenovo idéalpad 110-15ACL
      Originally posted by fire1234
      Pure bios To have sn numbers and windows key from the original bios you need to copy the LENV block
      Hi boss. How to copy the LVN Block to have the serial number and the name of the model?
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        Re: Lenovo NM-A841 (Ideapad 110-15) bios dump
        Originally posted by Alecuruzu
        i post here the BIOS from a working laptop
        thank you very much
        • lapfix
          • Mar 2020
          • 2720
          • my workshop
          Use HXD tool , select the data and (copy - paste) from one bios to another
          • djharold
            • Aug 2015
            • 241
            • COLOMBIA
            thankyou
            • beal
              • Jul 2017
              • 95
              • Iran
              #26
              Originally posted by SMDFlea
              Re: Lenovo IdeaPad 110 NM-A841 bios needed
              Try this one .
              hi
              tseted ok very thanks with model,serail Invalid ID
              Please can you merge the information from the old BIOS
              • peste
                • Dec 2016
                • 12775
                • ROMANIA
                #27
                Originally posted by beal
                hi
                read post #11
                • benzinformatique
                  • Nov 2022
                  • 25
                  • Algeria
                  #28
                  i need unlock this lenovo ideapad 110-15ACL
                  CPU : AMD E2
                  SN : PF0RK2LT
                  MTM 80TJ00A2FR
                  this is my dump
                  • peste
                    peste commented
                    Editing a comment
                    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                • peste
                  • Dec 2016
                  • 12775
                  • ROMANIA
                  #29
                  CPU : AMD E2
                  SN : PF0RK2LT
                  MTM 80TJ00A2FR
                  this is my dump
                  post motherboard model,TYPE,etc
                  • benzinformatique
                    • Nov 2022
                    • 25
                    • Algeria
                    #30
                    motherboard model : CG521 NM841 Rev 1.0
                    Model name 80TJ
                    CPU : AMD E2
                    SN : PF0RK2LT
                    MTM 80TJ00A2FR
                    mfg date 17/03/24
                    Factory ID : JVHFC1
                    • peste
                      • Dec 2016
                      • 12775
                      • ROMANIA
                      #31
                      Model name 80TJ
                      CPU : AMD E2
                      SN : PF0RK2LT
                      MTM 80TJ00A2FR
                      mfg date 17/03/24
                      Factory ID : JVHFC1
                      try post#2...
                      • mximiliandz
                        help bios lenovo ideapad s145-14iil type 81w6
                        by mximiliandz
                        Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                        06-20-2025, 06:50 AM
                      • jendkkd jeje
                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                        by jendkkd jeje
                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                        10-11-2024, 03:12 PM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • grimacelord
                        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                        by grimacelord
                        Hello there.
                        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                        History:
                        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                        I searched for this error online and discovered...
                        03-15-2023, 03:29 PM
                      • Popel1083
                        Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                        by Popel1083
                        I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                        SN: QB08570065
                        MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                        08-06-2024, 05:52 PM
