toshiba c55-b803 need bios
  • alibisma
    • Oct 2014
    • 37
    • Saudia
    Daoblimb6e0 rev e i have this old bin file . Can someone provide me new bin file
    • 22293
    Re: toshiba c55-b803 need bios
    Try this one: https://drive.google.com/file/d/0B6I...ew?usp=sharing
    • alibisma
      • Oct 2014
      • 37
      • Saudia
      i try this already its deffrent buffer not woorking
      • alibisma
        • Oct 2014
        • 37
        • Saudia
        ala_borbe?
        hello bro could pls find this bios i mentined above
        • alibisma
          • Oct 2014
          • 37
          • Saudia
          nobody have bios this model
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            hello
            i dont chek all the thread... if you do not get help, send me a PM
            here is bios you need
            Im Back... sort of...
            • alibisma
              • Oct 2014
              • 37
              • Saudia
              thanks bro did u see old bios buffer its deffrent then new
              • alibisma
                • Oct 2014
                • 37
                • Saudia
                no display bro see old bios buffer
                • alibisma
                  • Oct 2014
                  • 37
                  • Saudia
                  ok thanks bro its working the problem is rtd2132n thanks
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • maanee11
                    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                    by maanee11
                    Hello Everyone,
                    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                    In the website, you can only see specs etc.
                    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                    11-08-2025, 04:08 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    Hi everyone
                    09-06-2025, 05:47 PM
                  • HOHA
                    BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                    by HOHA
                    Hi can you help me
                    I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                    IP3_TN16S_MB_V30_20210901A
                    This is the old BIOS file, it is corrupted​...
                    10-20-2024, 08:22 AM
                  • nahidmirzayev
                    Toshiba Satellite P55T-A5202 BIOS file
                    by nahidmirzayev
                    Hello, Could you please help me to find bios files (2mb&4mb) for Toshiba Satellite P55T-A5202? I have already downloaded wrong bios files several times. Every time led behaviours are different....
                    10-14-2025, 11:48 PM
