kiano slimnote15.6
  • noname013
    • Jul 2015
    • 18
    • moldova
    kiano slimnote15.6
    need bios for kiano slimnote 15.6 with hdd and intel atom cpu and ram4gb
    the motherboard model
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: kiano slimnote15.6
    Two different years of manufacture? LOL
    (I see what looks like week 46 of 2011, while I clearly see 2017 on the upper right!)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      • 20611
      Can you post your bios backup .What problem are you having .
      • noname013
        • Jul 2015
        • 18
        • moldova
        hi yes I have back up of BIOS, but I backup after I make changes in bios, I disabled usb xhci and now the keyboard and usb don't work, I try bios from chuwi lapbook and prestigio but with bios from prestigio I can only install w10x86, and with bios from chuwi I can install w10x64 but not work sound(driver is instaled but no sound) and not work wifi in device manager is not listed wifi, and lan not work correctly.
        what I need is, if someone can to edit my bios to be enabled usb
          • 20611
          Try this bios.
          • noname013
            • Jul 2015
            • 18
            • moldova
            Try this bios.
            thanks but with this dump computer not working, the power light is flashing and black screen
              • 20611
              I`ll post another bios later.
              • rioreno
                • Feb 2009
                • 540
                • Indonesia
                Try this... nvram clear ,back to default setting...
                • noname013
                  • Jul 2015
                  • 18
                  • moldova
                  not working, the same like first .
                  I try with my backup, it work, I verify backup is ok, but dont work keyboard and usb
                  • noname013
                    • Jul 2015
                    • 18
                    • moldova
                    SMDFlea, and rioreno, sorry that i misleading you, probably I soldered bad the chip, with bios from smdflea computer start but the setting in bios is not changed and usb and keyboard not working BUT with your BIOS rioreno the bios is reset, and all seems to work, right now I installing w10x64 and will announce you if all is working, very very big THANK YOU
                    • noname013
                      • Jul 2015
                      • 18
                      • moldova
                      sound and wifi work also the 500gb hdd
                      • AlexCTP
                        • Dec 2018
                        • Russia
                        Hello.
                        I need help with my BIOS from Haier HI133L - when I change "OS Image Select" from "Windows 8" to "Android" my laptop stop working and the power light is flashing and black screen. HI133L have same schematic (motherboard) like kiano slimnote15.6 but without HDD - it have 32Gb SSD + 2GB RAM. Somebady please help me. BIOS dump attached to this message.
                        • rioreno
                          • Feb 2009
                          • 540
                          • Indonesia
                          Originally posted by AlexCTP
                          Hello.
                          Greetings..
                          This, nvram reset to default setting...
                          goodluck and please confirm
                            • 20611
                            Nice job @rioreno. Did you modify this just with a hex editor or with UEFITool .
                            • rioreno
                              • Feb 2009
                              • 540
                              • Indonesia
                              both,
                              use hxd for edit, use uefitool to get the offset..
                                • 20611
                                both,
                                Thanks, i`ll try it .
                                • rioreno
                                  • Feb 2009
                                  • 540
                                  • Indonesia
                                  Goodluck.
                                  Remember friend, every bios has a different nvram structure.
                                  So you should first look at a number of pure different bios brands obtained from the manufacturing site as a reference.
                                  • on/off
                                    • Oct 2016
                                    • 333
                                    • Indonesia
                                    Goodluck.
                                    Seem I need more lot talk to you to improve my skill of fix BIOSes.
                                    Moga ente tetap sehat bro..alamat masih pajak atas?
                                    • AlexCTP
                                      • Dec 2018
                                      • Russia
                                      Greetings..
                                      Thank you rioreno very-very much!!!! Everything workig fine!!!
                                      • zaffinog
                                        • Oct 2021
                                        • italia
                                        Hi!
                                        i'm new to the forum, i need help restoring bios dump on my sbartbook mediacom s14, after setting android to default s.o. to start the smartbook I have the blank screen and the power led blinking, I dumped the bios but I have no idea how to reset nvram
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • Bloodhoundje
                                          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                          by Bloodhoundje
                                          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                          I have desoldered the bios chip (GigaDevice...
                                          03-16-2024, 03:12 PM
