Need Asus A451L
  • kodox
    • Jul 2017
    • 330
    • Indonesia
    Need Asus A451L
    I need BIOS Dump Asus Laptop
    Board Model: S451LN REV. 2.0
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: Need Asus A451L
    Originally posted by kodox
    i need bios dump asus laptop
    board model: S451ln rev. 2.0
    plz test
    • kodox
      • Jul 2017
      • 330
      • Indonesia
      Need Asus A451L
      Could someone verify this file, the file was downloaded from official asus support web, should i flash it directly or it need "extra" modification before i flashed to the chip?
      • kodox
        • Jul 2017
        • 330
        • Indonesia
        Re: Need Asus A451L
        Originally posted by mahmoodjavan
        plz test
        Sorry bro, i didn't see your post. OK, i'll try it & report the result.
        @mahmoodjavan, It still the same after i flashed the bios. the problem with this laptop is the onboard ram got heated up after power button pressed & the display blank on lcd or external monitor before flashing the bios with file you gave, then i try disabling onboard ram using guide i found in this forum with the same result and last i flashed the bios using the file you gave to me and no improvement.
        do you think should i cut the power to onboard ram or just remove all the onboard chip from the board or you have another method?
        • kodox
          • Jul 2017
          • 330
          • Indonesia
          Re: Need Asus A451L
          anyone...? please...
          • cacla
            • Apr 2015
            • 444
            Re: Need Asus A451L
            Here it is
              • 22279
              Re: Need Asus A451L
              EDIT: Removed bios .
              • kodox
                • Jul 2017
                • 330
                • Indonesia
                Re: Need Asus A451L
                Originally posted by cacla
                Here it is
                ok i'll try it. thank's
                • kodox
                  • Jul 2017
                  • 330
                  • Indonesia
                  Re: Need Asus A451L
                  @cacla
                  the problem remain after flash the bios with file you gave bro...
                  • cacla
                    • Apr 2015
                    • 444
                    Re: Need Asus A451L
                    Give me the sn form your unit
                    • kodox
                      • Jul 2017
                      • 330
                      • Indonesia
                      Re: Need Asus A451L
                      A451LN-WX028D or this one EAN0CX00091040E
                      when power button pressed, onboard ram chips on both side of the board get hot. is it normal?
                      • cacla
                        • Apr 2015
                        • 444
                        Re: Need Asus A451L
                        No man it is not normal you try to disable the onboard ram ?
                        BTW my bios is ok its for you unit. You dont have bios issue.
                        • kodox
                          • Jul 2017
                          • 330
                          • Indonesia
                          Re: Need Asus A451L
                          yes, i've disabled the onboard ram. but it's get hot before i disabled it
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • grimacelord
                            by grimacelord
                            07-10-2025, 02:52 PM
                          • Shamitha
                            Asus X540UA i3 8 generation Bios Dump / Bin File
                            by Shamitha
                            Can any one find me the bin file of Asus X540UA. Core i3 8 gen and on board vga. Bios are locked and need to flash new bios. Please help me !
                            04-23-2024, 02:38 PM
                          • Sebastian Codrean
                            BIOS file for ASUS F542UN laptop
                            by Sebastian Codrean
                            Hello to all of you! I need help with a BIOS file.
                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                            02-20-2025, 10:25 AM
                          • ASB
                            Asus Prime B450-Plus Bios Modification (USB Overcurrent)
                            by ASB
                            I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
                            11-12-2025, 06:17 AM
