Can any one find me the bin file of Asus X540UA. Core i3 8 gen and on board vga. Bios are locked and need to flash new bios. Please help me !
Asus X540UA i3 8 generation Bios Dump / Bin File
Post the full laptop model number,post your backup,type and post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
Also,post a picture of the QR code or long barcode sticker on the motherboard -
Every donation made will go towards server fees and maintenance costs.Comment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
- Loading...
