bios password dell latutide 3540
Re: bios password dell latutide 3540
You need only 5 pins-KS03/KSI4/KSI5/KSI6/KSI7 and need to connect them with RT809F.
Remember,
KSI4=CS
KSI5=CLK
KSI6=DIN
KSI7=DO
KS03=GND
With the above information you can easily find out the pins of RT809F but where to connect on mb kbd connector-you need to find out in schematics.Comment
thank you so much my friend but today i did buy Vertyanov 3.1 but icant find motherborad number in the software i think i will do it manulyYou need only 5 pins-KS03/KSI4/KSI5/KSI6/KSI7 and need to connect them with RT809F.
Remember,
KSI4=CS
KSI5=CLK
KSI6=DIN
KSI7=DO
KS03=GND
is those the important pin in all motherborad and can you show me how to do it with vertyanovYou need only 5 pins-KS03/KSI4/KSI5/KSI6/KSI7 and need to connect them with RT809F.
Remember,
KSI4=CS
KSI5=CLK
KSI6=DIN
KSI7=DO
KS03=GND
Dear @nabilgo, i dont use vertyanov and dont have much idea about it. I use svod where you can download the pinout file for particular mb from online database. i think it should be almost similar procedure for your programmer as well.
As far as clean kbc dump is concerned, please let us know the mb part no like LA-XXXX and Rev no.Comment
la-a491pDear @nabilgo, i dont use vertyanov and dont have much idea about it. I use svod where you can download the pinout file for particular mb from online database. i think it should be almost similar procedure for your programmer as well.
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
Thanks.
1hj4z24 = Service tag
A schematic would also be amazing if anyone has one!...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
- Loading...
