can any one unlock this bios for me pls
bios password dell latutide 3540
Re: bios password dell latutide 3540
Have you tried the password at bios-pw.org .The bios password is stored in the KB9012 EC on this model. https://cdn.badcaps-static.com/pdfs/...928fc3eda7.pdf -
Would you try this...
If it doesnt work,so right the password store at kbc..
better nice to try...
goodluck and please confirm...Attached Filesif you find these attachements useful please consider making a small donation to the site
Password goes to KBc in this model-100% sure. So need to flash kbc. No other way to remove password.Comment
are you sure?
check this:
https://www.badcaps.net/forum/showthread.php?t=71015
Password for e7440 should store at MEC5075...
https://cdn.badcaps-static.com/pdfs/...29786511cb.pdf
e7440 can unlock with flashing bios only not MEC...
better nice try...Comment
The e7740 you linked to had a very old bios version A14, so the EC would be an older version as well. Version A17 bios changed the password algorithm , and the latest bios has a new master password lockout, idon`t know if a bios downgrade would work if the latest bios and EC was flashed ?are you sure?
check this:
1. We talk about this thread right?The e7740 you linked to had a very old bios version A14, so the EC would be an older version as well. Version A17 bios changed the password algorithm , and the latest bios has a new master password lockout, idon`t know if a bios downgrade would work if the latest bios and EC was flashed ?
2. Fact , the lock file: noman dell ori psw.rar are ver.A09( you can check by hxd)
3. The new file i rebuild from e7440a14.exe, how about that??...
How do you see that fact bro??
@nabilgo, please do the flashing, so we will know the results...Last edited by rioreno; 11-27-2018, 08:18 AM.Comment
Dear Rioreno, anybody can be wrong-no fighting for that. If my memory is not failing, then e3540 password goes to kbc. Yeh, agreed it dependes on platform to platform. Its not universal that password will be stored in kbc but as far as i remember, latitude e3540 pass stored in kbc.
Let nabiglo flash the bios first so that confusion goes away.Comment
Therefore I ask you, are you sure you have ever faced a case with this e3540? because for this E3540 has never been discussed for password bios cases on our forum.Dear Rioreno, anybody can be wrong-no fighting for that. If my memory is not failing, then e3540 password goes to kbc. Yeh, agreed it dependes on platform to platform. Its not universal that password will be stored in kbc but as far as i remember, latitude e3540 pass stored in kbc.
I wasn`t disputing that the e7740 bios worked ,i made a few typo`s and i`ll admit i`m wrong about that. Aren`t we all here to help ?Comment
I am sure we are in the same spirit, spirit to help ...
I still have to learn a lot.
I say from my quote, "better nice to try" there's nothing wrong with trying to make sure. Whatever the results from Nabilgo, there will be lessons learned later,especially by me...Comment
Yes as far as i remember i faced this issue on dell latitude e3540 at my bench and resolved it by flashing kbc. Do we post every case on which we work-no thread on forum doesnt mean, nobody faced it.Comment
Yeh, agreed dear. We'll are here to learn ourselves as well help the badcaps community.Comment
[QUOTE=rioreno;864951]1. We talk about this thread right?
@nabilgo, please do the flashing, so we will know the results...[/QU
hi
when i flash with new bios he start with black screen and 1 bip and i did put new kbc and still has password i dont know what to do ???? the kbc i idid remove it from another laptopComment
he start with black screen and 1 bip and when i put back the old bios he start normaly with password in biosComment
Forgive me, it seems that there is little missing from what I have done.
Will you try 1x again ... if it fails then I give up ...
The NVRAM module I extracted turned out to have to change the header layout first ...
please try again ..Attached Filesif you find these attachements useful please consider making a small donation to the site
[QUOTE=nabilgo;865434]1. We talk about this thread right?
hi
You did changed the kbc from another board but did you programmed it?? I dont think it will work without flashing even if we forget about password.
Btw, what's mb part number??Comment
still 1 bip with black screen thank youComment
If you made an EC backup can you post it .Comment
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Dear Sir,
I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
Problem details:
* Service Tag: (HMHJQ93)
What I need:
Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
In the attachment...-
Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
Thanks.
1hj4z24 = Service tag
A schematic would also be amazing if anyone has one!...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
- Loading...
