Dell Venue 10 Pro 5055 silverton mb 14238-1 wx4xd Bios
by davincemzHello IM looking for Dell Venue 5055 Pro Boardview and schematic
Channel: Schematic Requests ONLY!
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by jeewanthaDell Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
I already write 2 bios files. For both files it is not on.
Only light up top cover LED..
Machine Model : Dell Venue 10 Pro 5055
Service Tag: GWV0G32
Board Model Number : SILVERTON MB
14238-1
WX4XD
Please help to fix this problem. ...-
Channel: BIOS Requests ONLY!
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
