Asus U36JC bios dump file needed
  • ScApi
    • Oct 2016
    • 14
    Hi everyone, I need a bit of help with this Laptop.
    When it came to me it had corrupted bios, (over 30 min startup and random BSOD's), so I've tried to update bios (from asus website) but that did nothing, then I've found bios dump floating somewhere on internet and reprogrammed it, but now the tricky part.
    Laptop works like it supposed to but without LAN (got error code 10)
    On original bios everything with LAN was ok.
    Tried to Clear ME in original bios dump but random bsods still happen.
    Tried to copy MAC that I've found in org bios to one that I've downloaded but still same effect (no LAN).
    Can anyone help ?
  • cacla
    • Apr 2015
    • 442
    Re: Asus U36JC bios dump file needed
    Here
    • wakethesleep1111
      Bios File Needed for asus tuf15
      by wakethesleep1111
      Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
      05-27-2025, 10:56 PM
    • Sebastian Codrean
      BIOS file for ASUS F542UN laptop
      by Sebastian Codrean
      Hello to all of you! I need help with a BIOS file.
      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
      02-20-2025, 10:25 AM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
