Need BIOS Samsung NP900X3E-A02US
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Hey all,
    I am in need for Bios dump:
    AMOR2-13-MONO REV1.0
    8 mb file size.
    I will upload backup.
    No picture on screen so I want to try flashing BIOS.
    Thank you in advance.
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: Need BIOS Samsung NP900X3E-A02US
    Bump please see me...
      • 21946
      Try this one.
      • BremiX
        • Oct 2017
        • 64
        • Latvia
        Originally posted by SMDFlea
        Try this one.
        Didn't work.
        I flashed Bios for NP900X3C code has many differences but it give me some kinda picture on screen and i can use arrows to navigate and those lines/colors change on the screen. I will attach picture.
        I can even see jump in power from 0.600 ish Amps to almost 1 Amp when those lines/colors appear.
          • 21946
          The bios i posted was your bios,with a clean ME area .Try with an external monitor. It looks like a bad screen or gpu issue .
          • JersonP
            • Mar 2020
            • 30
            • mozambique
            Np900x3E amor2-13-mono
            please bios
            • Giulianoyula
              • Feb 2020
              • 8
              • Argentina
              hi friends, i tried all bios but some no image, and other display with colors, put THE original BACK with fault of infinite loop in samsung
              Samsung NP900X3E-A02VE
              SN: JC1B91GD500098Z
              attached my orig bios, some help please
              • noname2024
                • Aug 2024
                • 295
                • CỎ MỸ XỊN
                SN: JC1B91GD500098Z
                [900X3C/900X3D/900X3E/900X4C/900X4D] Amor2-CRV Win8 BIOS/MICOM (P11ABK)
                • Aliencomputres
                  • Aug 2019
                  • 218
                  • România
                  Didn't work.
                  Bad screen or gpu,first.
                  • Giulianoyula
                    • Feb 2020
                    • 8
                    • Argentina
                    INCREDIBLY IT WORKED PERFECTLY, THANK YOU VERY MUCH!!
                    HOW DID YOU FIND THE BIOS?
                    GREETINGS
                    • noname2024
                      • Aug 2024
                      • 295
                      • CỎ MỸ XỊN
                      GREETINGS
                      read your original bios to see what model it is. then check rma factory bios from samsung Click image for larger version
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        08-01-2025, 09:15 AM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
