Medion md99530 bios
  • Blitzbirnle
    • Sep 2021
    • 19
    Re: Medion md99530 bios
    i need help! I got the ch341A Programmer with ASProgrammer Software and I have a Medion Akoya E6416 99560 with a trash BIOS.
    MB Info:
    D15D MAIN BOARD rev 2.1
    BIOS 1 MX25L1673E
    BIOS 2 MX25L3273E
    I found two BIOS chips (EC and Main). I would like to flash them, but the program does not allow me to do so or does not recognize either of them.
    I put the clip in the right position (Red wire - 1) and tried to detect the chip, but it says "IC not responding". I checked and its connected perfectly.
    Someone got any ideas?
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      MB Info:
      BIOS 1 MX25L1673E
      BIOS 2 MX25L3273E
      remove the chip from the motherboard and solder it to the pragrammer, or solder wires between the chip and the programmer.
      • Blitzbirnle
        • Sep 2021
        • 19
        Got both out and soldered it to a PCB that came with the Ch341A programmer but the same effect...
        • Blitzbirnle
          • Sep 2021
          • 19
          Has anybody an idea?
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            download this program .... do you have the same problem with the other chip ??
            https://www.badcaps.net/forum/showpo...04&postcount=7
              • 22279
              Try NeoProgrammer software,both chips are supported https://www.badcaps.net/forum/showpo...50&postcount=5 .Choose each chip manually.
              There`s a link in that post as wel to a 3.3V mod for the black PCB ch341a ,to convert it from 5V, it will make it a bit more stable. You can do the mod easily if you have a soldering iron.Its a good idea to resolder all the pins on it as well, i had 2 ch341a`s that arrived DOA and resoldering fixed both.
              • Blitzbirnle
                • Sep 2021
                • 19
                Okey i´ll try later and let you know.
                From a Sony Vaio SVF153a1ym I already succesful read wrote and verified a BIOS chip but I got only stucked with this one.
                • Blitzbirnle
                  • Sep 2021
                  • 19
                  I already did this, very clean!
                  • Blitzbirnle
                    • Sep 2021
                    • 19
                    I tried it yesterday and it works perfectly! I don't understand why some programs are different, but anyways...
                    Another Problem: The BIOS 1 MX25L1673E was recognized and flashed successfull.
                    The second BIOS MX25L3273E was also recognized but I couldn't flash it. It says Error on adress 00000010. Someone got another BIOS? (4MB)
                      • 22279
                      There`s nothing wrong with the files at posts 4 and 7 ,the error is because of a bad connection or the chip itself is faulty
                      • Blitzbirnle
                        • Sep 2021
                        • 19
                        yes you´re right... Got another one and it worked. But my Laptop does still not power on...
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • istvanszasz99
                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                          by istvanszasz99
                          Product Name: Razer Blade 15 (2022)
                          Product ID: RZ09-0421
                          Motherboard: CH580
                          BIOS Versions I work with: 2.02 & 2.06
                          Bios File Size: 32,768 KB
                          Dear Forum Readers!
                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                          !!! MY RAZER BLADE...
                          11-24-2025, 05:52 PM
