Medion md99530 bios
  • Blitzbirnle
    • Sep 2021
    • 16
    Re: Medion md99530 bios
    i need help! I got the ch341A Programmer with ASProgrammer Software and I have a Medion Akoya E6416 99560 with a trash BIOS.
    MB Info:
    D15D MAIN BOARD rev 2.1
    BIOS 1 MX25L1673E
    BIOS 2 MX25L3273E
    I found two BIOS chips (EC and Main). I would like to flash them, but the program does not allow me to do so or does not recognize either of them.
    I put the clip in the right position (Red wire - 1) and tried to detect the chip, but it says "IC not responding". I checked and its connected perfectly.
    Someone got any ideas?
    • peste
      • Dec 2016
      • 12781
      • ROMANIA
      MB Info:
      BIOS 1 MX25L1673E
      BIOS 2 MX25L3273E
      remove the chip from the motherboard and solder it to the pragrammer, or solder wires between the chip and the programmer.
      • Blitzbirnle
        • Sep 2021
        • 16
        Got both out and soldered it to a PCB that came with the Ch341A programmer but the same effect...
        • Blitzbirnle
          • Sep 2021
          • 16
          Has anybody an idea?
          • peste
            • Dec 2016
            • 12781
            • ROMANIA
            download this program .... do you have the same problem with the other chip ??
            https://www.badcaps.net/forum/showpo...04&postcount=7
              • 20855
              Try NeoProgrammer software,both chips are supported https://www.badcaps.net/forum/showpo...50&postcount=5 .Choose each chip manually.
              There`s a link in that post as wel to a 3.3V mod for the black PCB ch341a ,to convert it from 5V, it will make it a bit more stable. You can do the mod easily if you have a soldering iron.Its a good idea to resolder all the pins on it as well, i had 2 ch341a`s that arrived DOA and resoldering fixed both.
              • Blitzbirnle
                • Sep 2021
                • 16
                Okey i´ll try later and let you know.
                From a Sony Vaio SVF153a1ym I already succesful read wrote and verified a BIOS chip but I got only stucked with this one.
                • Blitzbirnle
                  • Sep 2021
                  • 16
                  I already did this, very clean!
                  • Blitzbirnle
                    • Sep 2021
                    • 16
                    I tried it yesterday and it works perfectly! I don't understand why some programs are different, but anyways...
                    Another Problem: The BIOS 1 MX25L1673E was recognized and flashed successfull.
                    The second BIOS MX25L3273E was also recognized but I couldn't flash it. It says Error on adress 00000010. Someone got another BIOS? (4MB)
                      • 20855
                      There`s nothing wrong with the files at posts 4 and 7 ,the error is because of a bad connection or the chip itself is faulty
                      • Blitzbirnle
                        • Sep 2021
                        • 16
                        yes you´re right... Got another one and it worked. But my Laptop does still not power on...
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • JoWed
                          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                          by JoWed
                          Hello Community,
                          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                          07-01-2025, 09:32 AM
