HP g62-445dx need bios
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi friends, I need a working bios for this model HP G62-445DX board id: DAAX1JMB8C0 REV: C INTEL CORE I3 no discrete graphics please.l
    • 20892
    Re: HP g62-445dx need bios
    Post your bios backup....
    • String2016
      • Nov 2015
      • 2238
      • philippines
      ok here is the original backup main bios attached
        • 20892
        There isn`t a G62-445DX ,there`s a G60-445DX .Is that the correct motherboard id.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          Its G62-455DX Serial no:CNF1014K3Z sorry mistake typical error
          • String2016
            • Nov 2015
            • 2238
            • philippines
            anyone please help need a working bios for this model HP G62-455DX please
              • 20892
              Here you go .
              • String2016
                • Nov 2015
                • 2238
                • philippines
                ok thanks i tried flashed main bios same issue i tried your ec but the chip cannot verify i tried original ok can verify. here is the backup EC bios can someone fix this please
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  need help please can someone fix my EC dump please
                    • 20892
                    You EC dump has the 1st 4KB duplicated at the end, the EC from hp i posted doesn`t. Ive added the extra 4KB to the end of the hp EC.Test it and post results .
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      thanks for the file above its working for me same board model
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • Babo Tech
                        Need bios bin Hp g42 daax1jmb8c0 rev:c
                        by Babo Tech
                        Hola a todos,
                        Llego al taller una notebook, Hp g42 daax1jmb8c0 rev:c, que enciande mas no da imagen, ya probamos con las ram, voltajes, salidas hdmi y nada, y por lo que veo es problema de bios,
                        si alguienme puede ayudar con dichas bios, se lo agradeciaria mucho.
                        A notebook arrived at the workshop, HP g42 daax1jmb8c0 rev:c, which turns on but does not give an image, we already tried with the ram, voltages, hdmi outputs and nothing, and from what I see it is a bios problem,
                        If anyone can help me with these...
                        02-03-2025, 07:19 AM
                      • Chris_stand
                        Clevo PD50PNN won't boot after BIOS Backup
                        by Chris_stand
                        i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                        At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                        Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                        But the...
                        04-28-2023, 03:08 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
