I need bios for this model hp DM1-3205au please. voltages present 3.3v on power button present and pin 7 and 8 of bios chip there is 3.3v but cannot turn on. I try to flash the bios first
hp dm1-3205au need bios
Re: hp dm1-3205au need bios
Here you go .Attached Filesif you find these attachements useful please consider making a small donation to the site
Take note of the kbc number and find a another schematic with same kbc. Check voltages on kbc. Follow logic---simple.Comment
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
