DEll Alienware m17x r4 biospassword
  • appie1206
    • Oct 2016
    • 116
    • netherlands
    Hello can someone help me with the masterpassword..
    My system is disabled need password Does someone has a generator?
    I only see payd sites... Does someone knows an other website where its free.
    Thank you!!!
  • zwect
    Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
    by zwect
    I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
    While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
    PCH doesn't seem to be shorted but i haven't done...
    12-29-2024, 06:57 PM
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • judamex
    Dell Alienware M15 R7 (intel) LA-L651P does not recognize Nvidia RTX 3060M dGPU
    by judamex
    Hello, I have a Dell Alienware M15 R7 INTEL LA-L651P which does not detect the dGPU which is a 3060M, I tried reprogramming both BIOS, without success, the dGPU has all the voltages, I do not know how to make it turn on properly with an external power supply, since outside the case, it only turns on for a second and turns off.
    I tested in vBios and on pin 2 of the eeprom I have no voltage, on pin 1 I do have 1.8V
    I also disabled the hybrid GPU in the BIOS settings and the Windows startup sound is heard but there is no image, with a color code of 2 red and 7 blue on the power LED. It...
    06-08-2025, 12:12 AM
  • claudyu07
    Dell Alienware m17x r2 BIOS dump
    by claudyu07
    Have this Dell here that got stuck during bios update to writing block 47 of 70.
    Motherboard : PCB: DELH-41-AB4400-AOOG
    I have download main(U8) and EC (U4) from vinafix and flashed both but no change.
    Symptoms: Powers on with black screen, fan spins, lights on, turns off then starts again with all those but it doesn't turn off anymore and it doesn't react to power button.
    Does anyone have a known working dump for this model?
    Also.. what does U17 do ?
    11-26-2021, 10:39 AM
