6050a2516401-a02 bios dump
  • ravenmx
    • May 2018
    • 177
    • puebla
    I need this bios 6050a2516401-a02 bios dump please help me. thanks you
  • adiserwis
    • Nov 2013
    • 14
    Re: 6050a2516401-a02 bios dump
    That should help
    • ravenmx
      • May 2018
      • 177
      • puebla
      The dump file is OK, Thanks you.
      • djharold
        • Aug 2015
        • 245
        • COLOMBIA
        thankyou so much, bin is OK
        • vickey_vip
          • Mar 2016
          • 135
          • India
          Originally posted by adiserwis
          That should help
          thanks it's working
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • bondminer009
            Need Bios for Latitude 7650 (No Original / dump bios file)
            by bondminer009
            Good Evening,
            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
            Thank You
            Salam,
            Three
            11-12-2024, 07:48 AM
          • joshAU
            BIOS file for N550JK (original dump attached)
            by joshAU
            Hi all.
            I'm looking for a BIOS file for an Asus N550JK.
            I have a Asus R552J, which I believe is identical to the Asus N550JK.
            I downloaded the latest BIOS (210) for the R552.
            It is named N550JKAS.210.
            The BIOS file is however only 6mb in size.
            I've read the chip with a CH341A programmer and verified the file.
            That file is actually 8mb in size.
            I'm wanting to remove the BIOS password from this unit.
            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
            08-09-2022, 08:06 PM
          • adelage
            Merge ECS Z77-H2 bios cap file with original dump
            by adelage
            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
            03-11-2025, 03:07 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
