ASUS X54C-RB01 issues: power cycles during cold boot or reset/exiting the BIOS
  • 486junkie
    • Jul 2018
    • 6
    Here's the story (should've gone on this forum years ago):
    My ASUS X54C-RB01 is having issues with power cycling when turning it on (cold boot), rebooting an OS (Windows or Linux), or saving changes and exiting the BIOS.
    The cycle when turning on the laptop is this:
    Power light is on steady, as well as the charger light, num lock and HDD lights turn on briefly, and turn off, repeats, and turns on fully (shows the ASUS logo, the boot screen choosing between Windows 10 Pro and Xubuntu 17.10.1 LTS) and works normally.
    The cycle when rebooting the laptop from either the OS or saving and exiting the BIOS:
    Power light is on steady, as well as the charger light, num lock and HDD lights turn on briefly, and turn off, and the power light turns off and on again, repeats, and turns on fully (shows the ASUS logo, the boot screen choosing between Windows 10 Pro and Xubuntu 17.10.1 LTS) and works normally.
    Also, the battery was draining rather quicker than before the issue started (goes about 1.75 or so hours and it dies), but, after a calibration, the battery is back to normal, but, Windows reports the battery has 1 hr and 45 min at 97% with the charger disconnected. I opened up the laptop to look and see what's going on, and I found out the screws for the heatsink/fan combo wasn't tightened up, so I tightened up the screws, and still no dice. I also notice the fan doesn't spin up when the laptop is powering up when it's supposed to. Wish I had the proper multimeter to check the capacitance of the SMD caps for any issues since the probes on my current multimeter are too big and slip easily.
    Could it be a motherboard or capacitor issue? The I/O works without issues, it's the power that's not working properly (the polarity for both the battery and charger is at full continuity).
    Specs:
    Motherboard: ASUS K54C 2GB RAM Soldered on (Max: 6GB)
    CPU: Intel Celeron Duo B820
    GPU: Intel HD Graphics
    HDD: Inland 480GB SSD
    ODD: DVD Burner
    Display: 15.6" 1366x768 (VGA and HDMI output as well)
    RAM: 2GB soldered, 4GB DDR3L (6GB total)
    Sound: Intel HDA
    Network: Atheros Gigabit PCIe Ethernet, Ralink Wireless N
    Chipsets: Intel (not sure what the model numbers are)
    Battery: Standard 4-cell ASUS OEM battery
    Charger: OEM ASUS Charger 19W
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: ASUS X54C-RB01 issues: power cycles during cold boot or reset/exiting the BIOS
    have you replaced or changed any hardware in the laptop before the problem arises?
    • 486junkie
      • Jul 2018
      • 6
      The processor I kept as-is, wireless card as-is, and the only things that were upgraded or swapped was the RAM from 2GB to 6GB, heatsink/fan combo back in 2013-2014 since the old one broke, and the HDD to an SSD back in 2016
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        test the laptop using only one RAM stick.
        • 486junkie
          • Jul 2018
          • 6
          Tested with one stick, did the same thing. I cleaned the CPU and heatsink with new thermal paste, sprayed DeoxIt onto the CPU socket and RAM socket. The laptop almost boots up the first time (I hear the optical drive spinning up, which is a sign), but, it's still acting up. Going to purchase a soldering iron that's meant for SMD everything, remove one cap at a time, and test them individually using an LCR multimeter to see what happens.
          • 486junkie
            • Jul 2018
            • 6
            Bought an LCR Meter, checked every capacitor, and about 6 capacitors are bad and the others are reading higher levels.
            Capacitors:
            1x 2D3 220uF 6.3V SMD (bad) --> 25uF (might be wrong readings)
            6x 68 EFK. C42 25V SMD (over) --> increments between 525uF-526uF (might be wrong readings)
            5x E246 560 2.5V SMD (bad) --> increments between 114uF-300uF (might be wrong readings)
            I cannot seem to find the 560uF 2.5V SMD capacitors anywhere and cannot get them from overseas due to charging more for shipping than the caps themselves.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              i think,though not sure, 560uf caps are there in HP G6 R12/13 series mb. Look for it if you have any scrap mb.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                Cheap LCR Meters are weak in measuring nonpolar capacitors. thus any approximate reading may indicate that the capacitor is probably not faulty.
                how old is the mainboard?
                are the capacitors looking dark or cracked?
                a photo of them could help.
                • 486junkie
                  • Jul 2018
                  • 6
                  The board is 6 years old and the LCR meter was $25. Some look a little bulky on top.
                  • i19
                    Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
                    by i19
                    Hi
                    I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
                    Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
                    I want to use an CH341A (new model with 3.3v) to flash it.
                    My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
                    Any tips on how to connect to it? Maybe something...
                    08-20-2024, 06:50 AM
                  • trbovan
                    Asus GL731GT Boot loop
                    by trbovan
                    Laptop is a GL731GT with the I7-9750h and GTX1650.
                    Full model number is gl731gt-rb71-cb
                    Serial: (placeholder for when I get home)
                    Board model: G531GT REV. 1.5
                    Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
                    I assembled and tested anyway. The bios worked, I was able...
                    10-04-2023, 07:27 AM
                  • acata
                    Asus X450LC REV 2.2 can't boot to anything
                    by acata
                    I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                    Power on normally. Boot to bios ok.
                    But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                    10-10-2023, 05:15 AM
                  • lukkihapsi
                    Asus Vivobook X515JA Weird Boot Issue
                    by lukkihapsi
                    Asus Vivobook X515JA Laptop
                    Issue :
                    Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                    Tried :
                    Cleaned inside for dust, applied fresh thermal paste. No Change!
                    Removed keyboard, Trackpad, fingerprint sensor. No Change!
                    Removed Internal SSD. No Change!
                    Updated BIOS to latest version. No Change!
                    Removed battery and pressing power button for 1 minute. No Change!
                    Weird Part :
                    Upon turning laptop ON, screen lights up - stays black,
                    I...
                    07-07-2025, 12:07 PM
                  • futadmytro
                    Asus g713qm-es94 stuck on boot bios problem
                    by futadmytro
                    sn^M4NRKD02753616E
                    MB- g533-6050a3250201-MB-A03
                    Stuck on boot after ROG logo, did not enter to bios
                    In flash bios , laprop boot but have video issue
                    orig bios...
                    06-25-2025, 08:07 AM
