hp g6-1000sa bios bin file
  • akande
    • Dec 2017
    • 278
    • Nigeria
    hp g6-1000sa MOBO ID; DAOR22MBCD0 REV R22 BIN FILE NEEDED PLS
    Its amd processor
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp g6-1000sa bios bin file
    USe search. there are many dumps in this forum
    • akande
      • Dec 2017
      • 278
      • Nigeria
      thanks for concern but i couldnt get d one that marched my mobo id
        • 22276
        Nothing on google for this ID DAOR22MBCD0
        You meant DA0R22MB6D0
        • okbalord
          • Jun 2017
          • 208
          • Algeria
          try this
          OKBALORD
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Dear akande, I've uploaded bin file for your mobo. there are 3 types of bios in this model. match your bid and flash.
            PS: This is Hp official bios-so you will loose dmi info which you need to fill using hp dmi tools.
            One of them will definitely work as long as its a bios issue
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Originally posted by okbalord
              try this
              Dear friend check post #1. He has clearly said its a amd mb and still you have posted i3 bios
              • skassas
                • Feb 2018
                • 6
                • Turkiye
                thank you so much. it worked
                • to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                  by to5it0
                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                  I have opened the laptop and identified the main BIOS chip...
                  10-24-2025, 01:35 AM
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • maanee11
                  Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                  by maanee11
                  Hello Everyone,
                  I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                  It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                  In the website, you can only see specs etc.
                  I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                  11-08-2025, 04:08 AM
                • wakethesleep1111
                  Bios File Needed for asus tuf15
                  by wakethesleep1111
                  Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                  05-27-2025, 10:56 PM
