DELL 5547 Bios, NEW, not DUMP
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • kenkaniff
    HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
    by kenkaniff
    Product Name: HP Pro x360 Fortis 11-inch G9
    System BIOS: U94 Ver.01.08.00 10/06/2023
    Serial Number: 5CG31946F5
    SKU Number: 85W05EC#AK8
    Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
    This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
    I needed to remove bios password...
    10-01-2025, 04:32 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
