Macbook A1707 820-00928-A bios dump needed...
Every donation made will go towards server fees and maintenance costs. -
Could someone help me clean ME region on this macbook pro?
A1707 EMC 3162 Touch bar
MB:820-00928-A
SN:C02VM1PWHTD7
laptop is in boot loop, same on external boot device and internet recovery. tnxAttached FilesComment
MB:820-00928-A
SN:C02VM1PWHTD7
laptop is in boot loop, same on external boot device and internet recovery. tnxLast edited by SMDFlea; 04-30-2024, 02:56 PM. Reason: Thread merged, do not post a request in multiple threads !Comment
Hello somebody can help me with Clean ME ?Thanks
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
tryAttached FilesComment
Dear everyone Im looking for the bios above, this comes in EFI lock, please remove and send me the clear BIN, thank you.Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Please, anyone can help me with this file, only black screen macbook pro a1707 emc3162, serial c02tx3m6htd5Attached FilesComment
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by rednix01Hi everyone,
I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...-
by Robin21Hello,
I'm replacing NAND (Upgrade 256GB to 1TB) and need a favor from someone who have this motherboard – 820-00928. I haven't checked resistant to the ground before replacing chips and after I've placed new chips I've notice low resistance on L9370 (number 1 on my attached picture) next to the U9310 (S2FPS04X01). 0,3 - 0,2 Ohm.
If someone will be so kind and could check this resistance I'll be pleased.
Thank you in advance!... - Loading...
