Bios / dump hp pavillion dv7
  • nacer
    • Feb 2016
    • 130
    • alger
    Hp pavillion dv7
    model dv7-7162.sf
    n° main goya / balen 1.0-ddr3 11254-3
    n° bios winbond 25q64fvis
    n° ec -ene- kb9016 qf a3
    cpu i
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • MDSI
    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
    by MDSI
    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
    Details:
    Model : HP OMEN 17-an012nf
    Motherboard Part Number : DAG3BAMBAF0 REV : F
    Serial Number (S/N) : 5CD7280D51
    BIOS chip : Winbond W25Q64VSIQ
    Programmer : EZP2023+
    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
    I already...
    07-28-2025, 07:11 AM
  • grimacelord
    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
    by grimacelord
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once...
    05-07-2024, 08:06 AM
  • DynaxSC
    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
    by DynaxSC
    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
    11-06-2022, 05:22 PM
