Mac air a1466-820-00165-a-lock
Re: A1466 bios passWORD help
You may also need to do a option-cmd-p-r three boots to clear any previous settings.Comment
Re: Mac air a1466-820-00165-a-lock
Hi guys need help removing password from thisAttached FilesComment
unlockedAttached FilesComment
Can anyone please help me remove this password??Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
3.2. Apple -> 3.2.2. 2012 to 2017
For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
Clear out the whole SVS store. There are other stuff in this store, no idea what they are for so better avoid doing this.
Invalidate the CBF2CC32 NVRAM variable in that SVS store which contains the encrypted password. You just have to change one bit in its name, so like replace the C with an A or whatever. Note that strings are UCS-2 encoded, so in the hex editor it'll show up as 0x43 0x00 0x42 0x00 0x46 0x00 etc.
If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.Comment
Yes, I did erase the flash, and reset with ALT, CMD, P, R, still only fan runs, no lights, but I downloaded another bios for the same motherboard it switches on but I cannot install the OS,, it is very very slow, what can I do now please help me I am in trouble the owner wants his MAC!!Comment
Yes, I did erase the flash, and reset with ALT, CMD, P, R, still only fan runs, no lights, but I downloaded another bios for the same motherboard it switches on but I cannot install the OS,, it is very very slow, what can I do now please help me I am in trouble the owner wants his MAC!!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Macbook Air
Model : A1466
EMC : 2925
SERIAL : C02PW1MTG940
MOTHERBOARD : 820-00165-ALast edited by fragga; 04-24-2023, 07:49 AM.Comment
Thanks, now it powers on, and a FLASHING GREY FOLDER with a Question Mark, I have tried to reach recovery options but it doesn't detec the SSD, I trued 2 SSDs and same thing, is there any way to make it detec SSD? sorry it is my First Macbook to do BIOSComment
It may be that the SSD is formatted as APFS but the BIOS in your Mac is old and it won't recognise this formatting. Try booting from a Mac installation and then see if the SSD appears. Format as EXTFS+ and reinstall.Comment
Does not show INTERNAL Recovery Utility After Pressing CMD + R, it only goes to INTERNET RECOVERY, I tried to connect Wifi, and do recovery nothing it just goes back to the same spotComment
It's worth getting a USB stick and putting a MACOS installer on it (say Monterey).
I have many USB sticks for each version of MACOS.
This should boot and allow you to reinstall.
I never use internet recovery.
Good luck!Comment
I have downloaded an INSTALLASISTANT.PKG and I took another Macbook, I installed it and it opens a bucnch of files, I created a bootable disk using my External SSD, I go to my Macbook air, connected EXTERNAL SSD, pressed CMD+R,, and nothing comes up except INTERNET RECOVERY!!! Am I missing something? Please bear with meComment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by DannyxGood day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter... -
by hellHello, I would like to talk about the problem. My Hikvison recording devices have a password, so the BIOS is written. Our problem is the serial numbers on the devices, as written, it works in offline mode, but I cannot change it to online mode in any way. I have the BIOS. I tried to edit it, but it could not find the serial number with the BIOS hex editor. I have the original serial numbers. Can you help me? Best regards.
model DS-7208hqhı-K1
main kod : ds-20899_P rev:2.007-23-2025, 01:20 AM -
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
Channel: BIOS Requests ONLY!
- Loading...
