Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Mac air a1466-820-00165-a-lock
try..Attached FilesPremium supporters get full download access and other benefits.
I have 2015 Macbook Air A166 13 inch
SN: C02SKKWRH3QD
EMC: 2925
Symptoms: It does not turn on and Power supply reads 14.8VDC and 110mA
Thanks in advanceAttached FilesPremium supporters get full download access and other benefits.
Re: Macbook Air 820-00165-A EMC 2925 bios password
This the first time posting and asking to unlock a
Macbook Air 1466 EMC2925 Serial No.C17Q53R4G490
THANKS......
mac book air A1466 emc 2925 820-00165-A locked efi bios
sn CPWS7G5BH3QD
MACBOOK AIR EFI LOCKED PLEASE TO REMOVE EFI LOCK
S/N-C1MQM2U6G940 EMC 2925
BOARD NO- 820-00165-A
please helpAttached FilesPremium supporters get full download access and other benefits.
Sorry, SMDFlea...you are right. The MacBook Air A1466 SN is: FVHYHWZAJ1WK.You can also read in the back cover EMC3178. The MoBo is 820-00165-A.
It must be the latest batch, because it has Big Sur installed without tricks. It has 8Gb RAM, and only 120Gb SSD (I'm going to change it, amongst other things, like the startup delay problem...annoying!).
EDIT: This happens even without internal SSD. Even when you reset NVRAM; the time between chimes is veeeery looong. The curious thing is that, once started, the machine works like a charm (well...with Big Sur...I don't like it, but it works normally). I was thinking about the SMC reset signal, which can be "delayed" by any reason. But all signals in the scope appears well, compared to an older, working normally board (older, of course).Leave a comment:
Hello everybody: I have a problem in the bench with an A1466. It takes a lot of time since you push the PWR until the chime sounds. After that, the machine runs perfectly. But it takes 20...30 secs to gimme the chime sound. I thought maybe it will be a problem in the BIOS. This machine is an A1466 EMC3178 (it has Big Sur, so maybe the firmware was updated in the process of Big Sur installation, because the original EMC was EMC2678). I'll go to update here the bin file which is (suposedly) giving me this error, so I beg your help. TIA for your always invaluable help.Attached FilesPremium supporters get full download access and other benefits.
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Macbookair A1466 820-00165-A EMC 3178. S/N FVFZR5XMJ1WK with a lock
pliz help to remove padlock and clean me for me this file.
attached isthe bkp file
Re: macbook air 820-00165-a emc 2925 bios password
try...Attached FilesPremium supporters get full download access and other benefits.
please remove password from my ybios dump for macbook air a1466 emc 2925 s/n=C02QH0MMG940Attached FilesPremium supporters get full download access and other benefits.
Re: Mac air a1466-820-00165-a-lock
Those models have T2 security, so it's not as easy to remove activation lock. There are numerous other threads on this excellent forum that discuss T2 unlocking. Best find which version of iBridge you have installed. I'd make another thread with your issue too.Leave a comment:
I have a a1989 that I got from marketplace but they guy who sold it to me ghosted me and I can’t get past the activation lock asking for his login any help? I’m not are well versed as all of you with computers also so sorry if I sound confusedLeave a comment:
by bruce35HP 600 G3 MT
SERIAL NUMBER MXL8301K1C Serial number in the file in bios
SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
Thank you very much...-
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
I need you to remove the BIOS key from this Compumax please, it shows a security error as soon as it turns on and from there it does not advance to Windows or anything, the PC model says it is a Compumax Onix Series with serial number 2323BPB02124 and the board model ADLN201D_MB_V02...
Channel: BIOS Requests ONLY!
by dongspy06CAN YOU HELP ME REMOVE PASSWORD IN BIOS MODEL LENOVO 21CSS0YV12 K14 SERIAL # PF42JGTA thank you in advance guys i attach the bin file that has a password...
- Loading...
