Mac air a1466-820-00165-a-lock
  • fragga
    • Sep 2021
    • 16
    • Mozambique
    #101
    Re: A1466 bios passWORD help
    Originally posted by kevingill
    I've removed the password from the bin file.
    Let us know if this works.
    Also same file , I think my programmer corrupted this dump first time I read it, the Mac only turns fan now , no display, even with the first file , is there any way to fix the dump? No display but fan is running
    • kevingill
      • Jun 2013
      • 152
      • England
      #102
      Did you erase flash, write and then verify the new ROM file?
      You may also need to do a option-cmd-p-r three boots to clear any previous settings.
      • odexh
        • Jun 2017
        • 4
        • sri lanka
        #103
        Re: Mac air a1466-820-00165-a-lock
        Hi guys need help removing password from this
        • miansh621
          Banned
          • May 2022
          • 133
          • pakistan
          #104
          unlocked
          • odexh
            • Jun 2017
            • 4
            • sri lanka
            #105
            thanks but it does not turn on
            • odexh
              • Jun 2017
              • 4
              • sri lanka
              #106
              Can anyone please help me remove this password??
              • peste
                • Dec 2016
                • 12371
                • ROMANIA
                #107
                try..
                • odexh
                  • Jun 2017
                  • 4
                  • sri lanka
                  #108
                  Thanks peste it works but keeps asking me for a pin code when i try internet recovery
                    • 20477
                    BIOS guides, methods, resources and tools -> https://www.badcaps.net/forum/showthread.php?t=103526 3. Password removal by laptop brand -> https://www.badcaps.net/forum/showpo...42&postcount=4
                    3.2. Apple -> 3.2.2. 2012 to 2017
                    For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
                    Clear out the whole SVS store. There are other stuff in this store, no idea what they are for so better avoid doing this.
                    Invalidate the CBF2CC32 NVRAM variable in that SVS store which contains the encrypted password. You just have to change one bit in its name, so like replace the C with an A or whatever. Note that strings are UCS-2 encoded, so in the hex editor it'll show up as 0x43 0x00 0x42 0x00 0x46 0x00 etc.
                    If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.
                    • fragga
                      • Sep 2021
                      • 16
                      • Mozambique
                      #110
                      Yes, I did erase the flash, and reset with ALT, CMD, P, R, still only fan runs, no lights, but I downloaded another bios for the same motherboard it switches on but I cannot install the OS,, it is very very slow, what can I do now please help me I am in trouble the owner wants his MAC!!
                      • peste
                        • Dec 2016
                        • 12371
                        • ROMANIA
                        #111
                        the file is just the same with the one I send in first post please check
                        the bios from post #97 is not the same as the bios from post #98...write the bios from post #98 correctly...
                        • peste
                          • Dec 2016
                          • 12371
                          • ROMANIA
                          #112
                          if it doesn't work, post the name, model, EMC, S/N, motherboard model...
                          • fragga
                            • Sep 2021
                            • 16
                            • Mozambique
                            #113
                            Macbook Air
                            Model : A1466
                            EMC : 2925
                            SERIAL : C02PW1MTG940
                            MOTHERBOARD : 820-00165-A
                            • peste
                              • Dec 2016
                              • 12371
                              • ROMANIA
                              #114
                              Macbook Air
                              Model : A1466
                              EMC : 2925
                              try..
                              • fragga
                                • Sep 2021
                                • 16
                                • Mozambique
                                #115
                                try..
                                Thanks, now it powers on, and a FLASHING GREY FOLDER with a Question Mark, I have tried to reach recovery options but it doesn't detec the SSD, I trued 2 SSDs and same thing, is there any way to make it detec SSD? sorry it is my First Macbook to do BIOS
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  #116
                                  It may be that the SSD is formatted as APFS but the BIOS in your Mac is old and it won't recognise this formatting. Try booting from a Mac installation and then see if the SSD appears. Format as EXTFS+ and reinstall.
                                  • fragga
                                    • Sep 2021
                                    • 16
                                    • Mozambique
                                    #117
                                    Does not show INTERNAL Recovery Utility After Pressing CMD + R, it only goes to INTERNET RECOVERY, I tried to connect Wifi, and do recovery nothing it just goes back to the same spot
                                    • kevingill
                                      • Jun 2013
                                      • 152
                                      • England
                                      #118
                                      It's worth getting a USB stick and putting a MACOS installer on it (say Monterey).
                                      I have many USB sticks for each version of MACOS.
                                      This should boot and allow you to reinstall.
                                      I never use internet recovery.
                                      Good luck!
                                      • fragga
                                        • Sep 2021
                                        • 16
                                        • Mozambique
                                        #119
                                        Good luck!
                                        I have downloaded an INSTALLASISTANT.PKG and I took another Macbook, I installed it and it opens a bucnch of files, I created a bootable disk using my External SSD, I go to my Macbook air, connected EXTERNAL SSD, pressed CMD+R,, and nothing comes up except INTERNET RECOVERY!!! Am I missing something? Please bear with me
                                        • kevingill
                                          • Jun 2013
                                          • 152
                                          • England
                                          #120
                                          You should hold the option key as it boots and select the external SSD installer.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • Dannyx
                                            UART (serial ?) splitter ?
                                            by Dannyx
                                            Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
                                            The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
                                            The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
                                            08-18-2023, 03:21 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                          • jowy
                                            dynabook satellite pro C40-G-126 bios
                                            by jowy
                                            Hello, I have problems with the BIOS password of my Dynabook C40-G-126, with motherboard IP3_CN16S_MB_V20_20201229B, I would like to change the BIOS to be able to change components because it is limited, it is the PYS26E with serial number 41100104H. I have searched the forum and there is a ".bin" file for my motherboard, but I don't know exactly if the serial number does something because on my device that ".bin" does not work or at least it does not remove the password.
                                            Thank you very much in advance for the help, I will keep you informed​
                                            09-28-2024, 03:47 AM
