Mac air a1466-820-00165-a-lock
    • 20695
    Re: Request Macbook a1466 bios unlock
    Originally posted by hackymc
    Sorry, now i put here the file. i dont see section attach, i am new.
    I will attach now.
    Isn`t it an early 2015 model.Post the EMC number
    • hackymc
      • Feb 2017
      • 33
      • Romania
      #82
      A1466 (2017)
      MB 820-00165-A
      EMC:3178
      Need clean. Tanks
      Original DUMP
      • peste
        • Dec 2016
        • 12652
        • ROMANIA
        #83
        A1466 (2017)
        MB 820-00165-A
        EMC:3178
        Need clean. Tanks
        Original DUMP
        try..
        • hackymc
          • Feb 2017
          • 33
          • Romania
          #84
          Re: Mac air a1466-820-00165-a-lock
          No power, no lights at charger.
          • peste
            • Dec 2016
            • 12652
            • ROMANIA
            #85
            if you wanted to delete your password this is what you need ... I think you wrote the bios with errors ... don't use the clip as it gives errors..remove the chip from the motherboard when you write it or read it or paste threads between the programmer and chip..after doing a PRAM reset ..
            • hackymc
              • Feb 2017
              • 33
              • Romania
              #86
              Yes, i remove the chip, i use MiniPro, i made SMC and PRAM reset, but no lights, no power.
              • hackymc
                • Feb 2017
                • 33
                • Romania
                #87
                Its working, thanks everyone. Thanks peste.
                • rookie_badcaps
                  • May 2015
                  • 12
                  • philippines
                  #88
                  request for clear lock
                  a1466
                  Serial number C02RF516H3QD
                  Configuration 13-inch MacBook Air (Early 2015)/1.6 GHz Core i5/128 GB SSD/4 GB
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11649
                    #89
                    a1466
                    Cleared lock
                    • zakeric
                      • Mar 2014
                      • 65
                      • Morocco
                      #90
                      a1466-820-00165-a lock
                      • CammyTier1
                        Tier 1 Assets
                        • May 2022
                        • 43
                        Re: plz remove this bios password
                        try
                        • rookie_badcaps
                          • May 2015
                          • 12
                          • philippines
                          #92
                          @ hoaca388
                          thanks man, hope you can teach how to for bios of mac, very thankful for this
                          test and it work, directly change the ssd with new os, very thankful
                          • rookie_badcaps
                            • May 2015
                            • 12
                            • philippines
                            #93
                            very thankful for zakeric,CammyTier1 for quick reply , iam very glad to join this group, thanks you hope to learn a lot from you guys
                            • Sajtisajti
                              • Nov 2019
                              • 9
                              • Hungary
                              #94
                              Hey guys! Is there someone who has A1466 EMC 2925 1.6GHz 8GB working clean bios? Sadly the original is useless, damaged. Corrosion on efi connector...
                              Thanks!
                                • 20695
                                Thanks!
                                Find one with clean ME firmware, use the forum search https://www.badcaps.net/forum/showth...A1466+EMC+2925 .You will need to edit in your own serial number thats on the case, and correct the fsys checksum ,see the video linked here
                                https://www.badcaps.net/forum/showpo...43&postcount=5
                                4.3. Apple
                                • Sajtisajti
                                  • Nov 2019
                                  • 9
                                  • Hungary
                                  #96
                                  4.3. Apple
                                  Hey! Thank You!
                                  I just found one, it was a tricky one. Yes i searched for these two terms, but 6 bios was wrong for this air, that was the time i wrote that post. In the end i just found one (Maybe from another site, i downloaded about 20efi with emc2925 mark.). Idk what was wrong with the other cleaned efis.
                                  • fragga
                                    • Sep 2021
                                    • 16
                                    • Mozambique
                                    #97
                                    A1466 bios passWORD help
                                    Board
                                    820-00165-a
                                    • peste
                                      • Dec 2016
                                      • 12652
                                      • ROMANIA
                                      #98
                                      Re: A1466 bios passWORD help
                                      Originally posted by fragga
                                      Board
                                      820-00165-a
                                      try..
                                      • fragga
                                        • Sep 2021
                                        • 16
                                        • Mozambique
                                        #99
                                        Originally posted by peste
                                        try..
                                        the file is just the same with the one I send in first post please check
                                        • kevingill
                                          • Jun 2013
                                          • 152
                                          • England
                                          #100
                                          I've removed the password from the bin file.
                                          Let us know if this works.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • Dannyx
                                            UART (serial ?) splitter ?
                                            by Dannyx
                                            Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
                                            The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
                                            The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
                                            08-18-2023, 03:21 PM
                                          • hell
                                            Hıkıvısıon serial problem
                                            by hell
                                            Hello, I would like to talk about the problem. My Hikvison recording devices have a password, so the BIOS is written. Our problem is the serial numbers on the devices, as written, it works in offline mode, but I cannot change it to online mode in any way. I have the BIOS. I tried to edit it, but it could not find the serial number with the BIOS hex editor. I have the original serial numbers. Can you help me? Best regards.
                                            model DS-7208hqhı-K1
                                            main kod : ds-20899_P rev:2.0
                                            Today, 01:20 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
