hi everyone plz remove this bios password and serial number thanks in advance
Mac air a1466-820-00165-a-lock
Tags: None
Re: Mac air a1466-820-00165-a-lock
its clean now. try it.Attached FilesComment
This one boots fast for me.
I hope it works for you.Attached FilesComment
try and let me knowAttached FilesComment
here yuou goIm Back... sort of...Comment
This will fix your problem if others don't work. 100% cleaned.
Make sure to do this steps after reflash:
Resetting NVRAM
i) Shut down your Apple Mac.
ii) Locate the following keys on the keyboard: Command, Option, P, and R.
iii) Turn on your Mac.
iv) Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
v) Hold these keys until the computer restarts and you hear the startup sound for a second time.
vi) Release the keys.
And after that... reinstall the OS!
IF YOU DON'T THE CLOUD WILL RESET PASSWORD
TECHMAN1025Attached FilesComment
A1466-820-00165-A bios lock
hi everyone plz clear the bios password thanks in advanceAttached FilesComment
Re: A1466-820-00165-A bios lock
hi brother
Macbook air 13 a1466 bios lock
Hey guys, i have this file locked bios. Help me to cleat it. I have tried other files which is posted here earlier, but nothing works out.
Due to region issues laptop goes late. Im attahing my original file here.
model a1466 emc 2925
board : 820-00165-aAttached FilesComment
Re: Macbook air 13 a1466 bios lock
i need clean my dump please.Attached FilesComment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
I need you to remove the BIOS key from this Compumax please, it shows a security error as soon as it turns on and from there it does not advance to Windows or anything, the PC model says it is a Compumax Onix Series with serial number 2323BPB02124 and the board model ADLN201D_MB_V02...
Channel: BIOS Requests ONLY!
by dongspy06CAN YOU HELP ME REMOVE PASSWORD IN BIOS MODEL LENOVO 21CSS0YV12 K14 SERIAL # PF42JGTA thank you in advance guys i attach the bin file that has a password...
by DannyxGood day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter... - Loading...
