Bios password remove 850 G3 HP
Read the rules first and please provide the missing info
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
Hello. Please help me with this bios. I removed the bios password, but the "Post power-on password" remained. I couldn't get it out.
SN: 5CG7500NNH
Thank you.Comment
CCC↵
https://www.badcaps.net/donateComment
Try this oneRe: Bios password remove 850 G3 HP
Thank you very much for your reply!
I used RCUnlocker and got a passwordless .BIN file that I flashed to the chip. I have checked the inscription and there are no errors. I mounted the chip on the motherboard and all that happens is that my Caps Lock and Power lights blink somewhat regularly.
i had same case and this file solved the problel
feedback plsAttached FilesComment
Hello everyone. I bought an HP 850 G3 laptop from Denmark on the Polish auction Allegxx which has a password for the BIOS. I unsoldered and read the 25Q128 chip. Can I count on removing the password? Thank youAttached FilesComment
After reading about RCUnlocker on the forum everything was unlocked. Thanks for the information posted here and the great tool RCUnlocker.Comment
Hello friends
Im here to ask help to clean ME and remove password from a working bios.
My only problem is i cant Enter setup bios cause have password.
HP Eliteboot 850 g3
chip: 25q128 (16mb)
sn: 5cg8090 zrj
SYSTEM BIOS N75 VER 01.24 01/30/2018
thanksAttached FilesComment
So. i did it.
1st USED DRAG DROP this file for rcunlocker.
file gerated:
850_g3_n75_unlocked (attached)
2nd programmed with ezp2019+
3th soldering
4th pc powers on with error: Authentication Failed.
cant do f1 ou f2 or f11 or del.
any help please? i user 25q128 (16mb flash)
All Help apreciated.Comment
Try
So. i did it.
file gerated:
3th soldering
All Help apreciated.Attached Files↵
You load the original bios to see if the old symptoms still appear.
hoaca388 thanks for that bios but unfortunately power on, bakligcth keyboard light, fan runing at maximo and no video.↵
so. i solve my problem without use you bios (thanks anyway). my problem was my programmer. i used ezp2019+ to read and flash. but after you bios also my old bios none working. no video.
so i try using another programmer (MiniPro Programmer) and work perfect. thanks anyway.
so, RCUnlocker_v_1_0 work perfect for unlock biosComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by beBossHi,
as noobie to this please excuse my lack of experience.
I am trying to remove a BIOS password from this machine:
HP ProDesk 400 G6 Mini
but so far I still have no success.
I bought CH341 programmer and decided to give it a try.
The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...-
- Loading...
