HP DMI Tool NBDmiFit
hi i have a hp elitebook 820 g1 with error machine is not in committed state which HP DMI Tool should i download -
Hello I have an Elitebook 840 g3 that recently the motherboard broke. I bought another that doesn't enable NFC am I able to use this to enable NFC on the new board I have on my laptop. If so could anyone point me in the right direction pleaseLeave a comment:
hello there
idk how to manipulate bios image bin file to unlock mpmLeave a comment:
Re: HP DMI Tool NBDmiFit
Can I unlock the bios password without chip bios programming? Like use smc.bin. Is it possible to generate smc.bin using wndmifit?Leave a comment:
I have an HP Elitebook 8440p and I have tried both HP Bios Config Utility as well as NbDmiFit and neither one works, please help me!!
I tried Nbdmifit and all the dos programs and it gives me error 0x89 each time, what does this error mean, I also tried wndmifit and biosconfigutility and both did nothing, how do I fix it
Hello!?? Please help me!!!!!!!Leave a comment:
Salute u Sir
Today one customer gave me HP EliteBook 840 G6,
need to use DMI Tools to re-enter the details that got lost
There is any compitible tool for that model???Leave a comment:
Hello all! I have HP Probook X360 11 G3 EE laptop with problem "black screen"
I reflashed the bios and now I can't add serial number by hp dmi tools, it show me error "This system board is not supported. Will not be able to set BIOS setting"
I tried versions 2.04 2.07 2.09 and 2.14
Can anyone help me please to write dmi
ThanksLeave a comment:
Help.I have EliteBook 2570p.
On HP product serial finder, this notebook's warranty started 2013, ended 2014.
On power on, I can read *Manufacture Program Mode set 4 of 10*
The error I am getting is *Product Information not Valid*
I can boot to Ubuntu / Mojave (dual booting linux and hackintosh)
I only have Ubuntu 22 and MacOS Mojave as dual boot on this notebook. I did not install Windows but I can find an extra hard drive to install Windows if needed.
I just want to know what tool I need to use. Please help?Leave a comment:
Thank you very much! This solved my problem! You are the best!SOO.. in case anyone else is wondering, I actually managed to unlock the MPM by running UEFIMPMUNLOCK.EFI in nbdmifit 2.13 from the EFI shell. Even though the program says it's not supported on my system (2.14 would be the right version, but has no UEFI) . After MPM unlock I can use the normal tools nbdmifit or wndmifit to write the detailsLeave a comment:
I have a question regarding HP Elitebook/ZBook G3 mainboard replacement and DMI data:
If I had dumped my bios from the bad motherboard with a SPI programmer, could I simply flash it to the new board? Would this make DMI editing unnecessary and I would be able to keep my integrated Windows license? What would happen to the MAC-ID?Leave a comment:
Hi all hope you can help.
A customer asked me to take a look at her Notebook. Upon booting the notebook and message appears.
Product Information to valid
The Following product information programmed into the system board is missing or invalid
System Board (00A) - System Board CT Number
The Notebook is a HP Notebook - 15-Ac107na
Does anyone have the proper DMI tools for this, i have tried a few and all i get is "accessed denied" when trying to set new config
I would be greatful for any help
Hi, I replaced the motherboard of a hp 820 g2 with one purchased on ebay,
I would like to know if I can change the serial number, so as to insert the one on the motherboard that was there before. I no longer have the old motherboard and I don't have the copy of the previous bios.
Thank you,Leave a comment:
https://www.badcaps.net/forum/showpo...&postcount=222Originally posted by Unique1234Hi
I have the same issue and when I try to use DMI NBDmfit tolls I get the error vendor code not supported. And get an error manufacturing programme mode set
and ask for S/n SKU, CT Number
i have enclosed bios is it possible to clear the ME section Please
Thank youLeave a comment:
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
Channel: BIOS Requests ONLY!
by tsavpynDear all,
I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
Now I have a problem that I am unable to dump my BIOS into bin file.
My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
I searched for FPT but there is no Linux version and none of them work.
I hereby request a copy of Intel Flash Programming Tool for Linux x64.
I would really appreciate it if anyone...-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
by tony359HI all,
I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because... - Loading...
