Lenovo Ideapad 310-15ABR bios needed
  • Chivo77
    • Aug 2024
    • 14
    • Argentina
    Originally posted by peste
    now you posted the contents of the chip correctly..how did you extract the contents of the bios chip???
    Ive read it with a svod 3. The mb wasnt even turning on
    • peste
      • Dec 2016
      • 13451
      • ROMANIA
      and now write back to the chip the content from post #22...the board does not have to be turned on..you also need to write the DMI information (you have the range in which they are also found there)
      the bios from post # 22is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
      select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
      • Chivo77
        • Aug 2024
        • 14
        • Argentina
        no luck my friend, I used the values you gave me at post #18 but regardless of everything ok (setup shows correct sn and all), fan still does the same. 1st time using hex editor and it was easier than I thought. Thanks for your help.
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • joven016
          Lenovo Ideapad S145 need working bios HELP!!
          by joven016
          Problem is blinking power led only
          i don't know exactly if it's s145-15igm or s145-14igm
          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
          Already tested some of posted bios here
          S145-14igm - success but invalid serial and not booting on OS
          S145-15igm - success with serial and some other info in bios but still not booting on OS
          already tried installing new windows but always booting on bios setup
          windows installer flash drive detected on...
          08-21-2025, 10:55 PM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
        • BOGOSY77
          BIOS NEEDED FOR : Lenovo IdeaPad Slim 3 15ABR8 NM-F031 Rev 1.0
          by BOGOSY77
          KS486/KS489/KS586/KS681 NM-F031 REV1.0
          S/N: PF4YX6CX
          Can someone clear or rebuild this one, no display, no fan, only power button on, after 2 hours keyboard back light blink once, that it.
          Thank you so much.
          08-20-2025, 02:45 PM
