Hp zbook 14 g2 bios dump needed
  • andrew25
    • Feb 2016
    • 221
    • Malawi
    Please guys if anybody had a dump for hp zbook 14 g2 share me....
  • foulou0238
    • Mar 2014
    • 109
    • France
    Re: Hp zbook 14 g2 bios dump needed
    hello
    the bios for this model i think its the same for 840G2 so look in forum for this bios and test it ....
    good luck
    • okbalord
      • Jun 2017
      • 204
      • Algeria
      yes the same i tested it
      OKBALORD
      • Murtaza527
        • May 2018
        • 257
        • Malaysia
        Hp zbook 14 g2 lock
        • Murtaza527
          • May 2018
          • 257
          • Malaysia
          Re: Hp zbook 14 g2 lock
          Pls help me to clean this
            • 20773
            Have you tried RCUnlocker ? https://www.badcaps.net/forum/showthread.php?t=98539
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • vinaypundith
              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
              by vinaypundith
              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
              So, I'm looking for a BIOS dump for this machine - a 16MB one....
              08-03-2024, 12:32 PM
            • James Maxwell
              HP DM1-4000er Bios Dump needed
              by James Maxwell
              I badly need bios dump for HP DM1-4000er,
              Model: HP DM1-4000er
              Motherboard: DA0NM9MB6D0 REV.D
              Product: QJ490EA#ACB
              Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
              10-28-2024, 05:38 PM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
