yoga 260 la-c581p rev1.0 16mb bios
  • vahagnhar
    • Apr 2025
    • 6
    • Armenia
    Thanks a lot! it worked!
    • jt76
      • Jan 2025
      • 6
      • Greece
      Hello. i need your help please. I bought a yoga 260 with locked bios. I tried with autopatcer but when i power it up it stays in lenovo logo and no button works. Now when i restore the original bios it gives me 0199 error code. Is it possible my bios backup is corrupted? Thanks in advance.
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        post S/N, full name and model, motherboard model, TYPE,etc.
        • jt76
          • Jan 2025
          • 6
          • Greece
          Type 20fd-002uge
          S/N MP14558V
          M/B AIZS3 U04 ?
            • 22279
            Type 20fd-002uge
            S/N MP14558V
            M/B AIZS3 U04 ?
            Post your EC backup.
            • jt76
              • Jan 2025
              • 6
              • Greece
              #26
              Sorry. What is EC backup?
              • jt76
                • Jan 2025
                • 6
                • Greece
                #27
                Problem solved. Thanks anyway!
                  • 22279
                  How did you solve it, can you explain as it would help others in the same predicament
                  • jt76
                    • Jan 2025
                    • 6
                    • Greece
                    #29
                    I found this bios fix for my motherboard in the internet. If its not allowed to upload from other sites delete this.
                    • juan667134
                      • May 2019
                      • 29
                      • peru
                      #30
                      Hi, could you help me with this BIOS? It turns on without a screen.
                      The model is AIZS1 LA-C581P rev 1.0 (2015-11-16)
                      Type 20FD-A01U00 s/n MP-13LGM9 16/16
                      • maf2003
                        • Jan 2021
                        • 29
                        Can some remove the bios password for this dump. I tired the lenovo autopatcher with no luck.
                        Lenovo yoga 260
                        LA-C581P rev 1.0
                        serial number is rubbed off but the motherboard number is 4043907900043
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • AYsys
                          Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
                          by AYsys
                          Hello dear forum members,
                          I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
                          I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
                          Nothing was flashed here — the BIOS was only backed up.
                          I created the backup using a CH341A Black programmer and NeoProgrammer....
                          09-13-2025, 11:05 AM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • beogeek
                          Lenovo Yoga Slim 7 14APU8 Bios Request
                          by beogeek
                          I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                          Attached is the bios dump in the state I received it...
                          10-24-2024, 12:54 PM
