Asus U31F need clear me dump
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    hi for all,
    please I need bios dump for Asus U31F, I don't have the original one ( delete it accidentally).
    I Have stripe on screen after Asus logo ( see attached picture), laptop works fine befor I flash the bios with dump from asus web site.
    thank you
  • cacla
    • Apr 2015
    • 442
    Re: Asus U31F need clear me dump
    try this one
    • sourcebf
      • Jul 2016
      • 431
      • N/A
      Originally posted by cacla
      try this one
      thanks, I will try it and reply soon
      • sourcebf
        • Jul 2016
        • 431
        • N/A
        sorry I was busy this days, dump works but with the same issu
        can someone clean me this dump for me please..
        PS it going like this (see attached picture) after showing bios setup
        • sourcebf
          • Jul 2016
          • 431
          • N/A
          If some one can help me just a little I will do clean me by myself ...I want to learn
          • cacla
            • Apr 2015
            • 442
            then its not bios
            • sourcebf
              • Jul 2016
              • 431
              • N/A
              then its not bios
              the dump that you provide me is clean me ?
              • mielta
                • Apr 2015
                • 368
                Hi
                Check an external Monitor
                • mielta
                  • Apr 2015
                  • 368
                  it looks like LCD or LCD Cable
                  • String2016
                    • Nov 2015
                    • 2229
                    • philippines
                    that is not a bios issue check external if it is not the same then your lcd screen is the problem if the same then you graphics has the problem
                    • sourcebf
                      • Jul 2016
                      • 431
                      • N/A
                      ok thanks for the advaces i'll find out an other LED sceen to test with...
                      • PACKETSTORM2
                        EC Dump Asus U31JG or U31F
                        by PACKETSTORM2
                        Hi
                        Need ec dump for Asus U31JG rev 2.0 or U31F rev 2.0, Thanks
                        04-15-2024, 05:22 AM
                      • kcp0085
                        Request BIOS dump for ASUS FA617NS-A16.R77600
                        by kcp0085
                        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                        Specs:
                        - ASUS TUF FA617NS-A16
                        - CPU: AMD Ryzen 7
                        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                        Thanks in advance!​
                        05-02-2025, 12:52 AM
                      • Tamo Neko
                        Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                        by Tamo Neko
                        I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                        What Happened:
                        I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                        • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                        • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                        What I Need:
                        • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                        02-12-2025, 11:29 PM
                      • Anchar777
                        ASUS P1412CE need BIOS DUMP
                        by Anchar777
                        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                        06-26-2025, 03:39 AM
                      • ninjanody
                        Asus n751jk -help- I need bios dump with clear me
                        by ninjanody
                        I need a bios dump for n751jk rv.2. The laptop is no responding to power button, but the led for power and charging are light up.
                        11-29-2022, 10:30 AM
