bios dump elitebook 840 g3
    Re: bios dump elitebook 840 g3
    Originally posted by Vesko356 View Post
    Excellent.
    Seems like I need to paste the pads on the motherboard and place the programmed chip directly over it then place the torch on it -- I've noticed that when it melts, the package aligns with the pads on the motherboard.
    But it doesn't work all the time --when the video should come up, it doesn't, the fan just spins. I'm going to erase twice and see if that helps.
      I am using a CH341 Programmer got on ebay for around $10 and you can place the cmos chip in the test clip they supply--its a little tricky but once you get the hang of it works fine.
        This clip is not intended for use with a WSON-8 chip, do yourself a favor and buy a proper one. I recommend this type - https://www.badcaps.net/forum/showpo...&postcount=228
        Become a Badcaps supporter
        Thanks to all supporters.​
          HP EliteBook 840 G3 6050A2892401-MB-A01
          attached backup is getting this error
          looking for clean bios
            missing DMI information try this...
            https://www.youtube.com/watch?v=9T57ktw8n3Y
              am getting challenge on "feature byte"
                In this backup FeatureByte is empty , where's the original dump
                  got it from client with this backup
                    This client/technicien didn't copy the DMI that's why you face this issue .
                    Maybe someone gonnag help you here , so be patient
                      Device serial number is?
                        Dmi stored in me region
                        when you will clean me section than dmi will be blank
                          Hello my friend
                          So in this typical case this is how to proceed especially many HP have the DMI in me region .
                          MUST have the original dump and copy the informations from me region section
                            HOPE THAT SOMEONE CREAT TOOL FOR hp dmi..
                              Hello my friend
                              yes you must have a originole backup
                              if not than you have to try many Initialized bios till it get work
                              otherwise you will suffer from no or late display
                                As far as I understood, dahnking was able to enter the rest of the data except FeatureByte, that's why I asked for the serial number to give him the FeatureByte data, but as far as I can see he still hasn't posted it.. I've already seen what you're showing but and I don't see how it helps - you see is there a serial number somewhere, cos I don't?
                                  no my friend , just to show you that his dumb have no DMI and i know that already you know that
                                    In short, we are all waiting for dahnking to reveal the serial number from the label of the laptop, but he prefers to remain silent for now.
                                      Thanks Vesko! I might get that
                                      I mistakenly removed the cmos chip before removing the main battery and got an error "unlockable content not available"
                                      Here is the file not sure is it corrupted?
                                        Yes it is.
                                        As I said do yourself a favor and buy a proper tool for the job, continuing to use the clip you showed is just ridiculous, and it won't lead to a successful outcome. That's for sure.
                                          hp elitebook 840 g3
                                          i need help to resolved this bios problem
                                          6050A2892401 MB A01
                                          Hp elitebook 840 g3
